07-22-2014, 09:04 AM | #1 |
Drives: 2018 Summit White Camaro 1SS Join Date: Mar 2014
Torco question...
I run 91 octane here in CA. I've noticed since adding Torco to get a 93 octane mix, when starting cold, there's no more "knock" noise coming from the engine. Would this make any sense, or is it in my head?
'18 Satin White Vinyl Wrapped 1SS, 6MT, Low Gloss Black Wheels, NPP Dual Mode Exhaust
Added: Diode Dynamics Black LED Sidemarkers, GM Dark Finish Tailights, GM ZL1 Black 3rd Brake Light, Black Plastidipped Bowties(front/rear), AFE Dry Drop In Filter, 12mm Spacers(front/rear) Last edited by Six.Two SC; 07-22-2014 at 09:48 AM. |
07-22-2014, 09:21 AM | #2 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Probably in your head.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
07-22-2014, 11:31 AM | #3 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
I use Torco all the time for our stupid 91octane here. And it works!! Of course I have a tune for when running Torco. I mix it up to 104octane on weekends upload the tune and tell the ole lady to hold on to her panties!!! So yes it does work!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
07-22-2014, 11:42 AM | #4 |
Going for Plaid
He's not questioning if it works. He's questioning the engine running quieter at idle.
07-22-2014, 12:03 PM | #5 |
Ragtop Rocket!!!
Oh I see. In that case I don't notice any difference on startup.
07-22-2014, 12:33 PM | #6 |
What you may hear cold is piston slap. It would have no effect with Torco
07-22-2014, 01:59 PM | #7 |
Thanks guys.
Added: Diode Dynamics Black LED Sidemarkers, GM Dark Finish Tailights, GM ZL1 Black 3rd Brake Light, Black Plastidipped Bowties(front/rear), AFE Dry Drop In Filter, 12mm Spacers(front/rear) |
07-22-2014, 04:29 PM | #8 |
Drives: Victory Red ZL1 Join Date: Jul 2012
Isn’t piston slap something that one typically associates with forged pistons? I believe the LSA uses the Hypereutectic piston which allows for tighter clearances/tolerances, thereby eliminating piston slap….no?
07-22-2014, 07:17 PM | #9 | |
709 RWHP & 677 RWTQ
Drives: 13' HPE 800 ZL1..... IOM vert, M6 Join Date: Feb 2013
11.34 @ 124.88
07-22-2014, 08:31 PM | #10 |
I do not know what the noise is, if it is knocking cold, then most of the time it's the pistons are not hot and up to the diameter of the bore. After it warms up they normally do not knock.
07-22-2014, 09:46 PM | #11 | |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
07-23-2014, 06:57 AM | #12 |
709 RWHP & 677 RWTQ
11.34 @ 124.88
07-23-2014, 11:19 AM | #13 |
Drives: 2013 VR ZL1 Join Date: Aug 2012
Maybe just around Odessa, I live in south Texas and we have 93, and I've taken the ZL all around Texas and not have had a problem with finding 93
2013 ZL1 Victory Red - 628
2015 Chevy Silverado Midnight Ed. 6.2 1500 LTZ Z71 |
07-23-2014, 01:18 PM | #14 |
Ragtop Rocket!!!
You are correct. West Texas area 91 is all you find. South, east, and North Texas has 93.
