01-15-2013, 08:36 AM | #1 |
2nd mosted hated in NM
Drives: Tuned for her Pleasure Join Date: Aug 2012
window question
My 2010 1 ss camaro gave me a message to roll window down then back up. I did it and now when i pull up on the window switch up it is not automatic. Also it is not going down that little bit when i open the door. B
01-15-2013, 10:59 AM | #2 |
It happens to me quite often. I usually give a quick press to let it go down automatically until it stops (fully down) then hold it up for a second or two after the window is all the way up and the message disappears.
01-15-2013, 11:01 AM | #3 |
What they said. Directions in owners manual under window indexing
01-15-2013, 11:08 AM | #4 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
Yup the first two posts got it ll covered for you.
01-15-2013, 11:38 AM | #5 |
Forever Pontiac
Drives: 2012 Black 2SS/RS Join Date: Oct 2010
I have 2 cars, the Camaro and a G6 coupe. They both have the same window structure that they need to go down/up when you open/close the door. After 7 years experience with it on the G6, never have had it just "stop working" it only seems to do it when I unplug the battery because that resets the computers "little brain" and you have to re-index it.
Unless it happens quite regularly, like said do the re-indexing and you're fine.
01-15-2013, 12:05 PM | #6 |
Thanks I would have looked in the manual. But since I bought the car used, its seems to be missing. Thanks i will give that a shot
01-15-2013, 04:26 PM | #7 | |
TCC SWFL Chapter
Drives: 2012 Camaro 2SS LS3 Black/IO Vert Join Date: Oct 2011
