10-01-2013, 12:35 PM | #1 |
Drives: 2012 2LT RS Join Date: Apr 2013
Adding Sat Nav console
So unfortunately i bought my camaro a year too early. Would really like a sat nav/touch screen system for my console. any suggestions?
10-01-2013, 12:41 PM | #2 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
An aftermarket system is the way to go, more features and better performance than the factory My Touch system.
10-01-2013, 01:00 PM | #3 |
Drives: ( . )( . ) Join Date: Feb 2010
10-02-2013, 11:43 AM | #4 |
Drives: 2SS/RS L99 Rally Yellow Sun Roof Join Date: Apr 2010
hey Christianmotox,
The only issue with the autospatech approach, which is awesome by the way, is you lose the ability to lock and unlock your doors. ~E |
10-02-2013, 11:51 AM | #5 |
Really? that would suck. I havent done it yet, but i did asked for a quote.
Thanks for the heads up, if i do it i will remember to ask them about that. Do you know why? i mean the unlock button is on the door know.
10-02-2013, 11:55 AM | #6 |
I have a 2010 and the unlock button is on the unit itself. If I switch to the My Touch which doesn't have a lock/unlock button then I lose that ability.
10-02-2013, 05:43 PM | #7 |
Oh i see, but if you have the unlock button on the door you should be OK.
10-02-2013, 07:58 PM | #8 |
The MyLink system doesn't work unless you have the BCM to support it. You're better off spending the money on an aftermarket system. It'll sound much better and give you more features anyway.
10-02-2013, 08:03 PM | #9 |
This does require reprogramming by the dealer, did you checked the link I posted?
10-03-2013, 09:30 AM | #10 |
It's not just about sound, some of us want that "stock" look. Watching the video by autospatech it looks like it's achievable.
10-03-2013, 10:34 AM | #11 |
Anyhody knows what's it going to cost more or less?
10-03-2013, 10:57 AM | #12 |
That upgrade is to add the OEM navigation to an existing non-navigation MyLink system. GM uses an entirely different BCM for the Camaros that have MyLink. The dealership isn't able to program a non-MyLink BCM to the MyLink system.
10-03-2013, 11:36 AM | #13 | |
They will provide you will all the hardware, cables etc. all you have to do is take It to the dealer and haven them reprogram. They provide instructions for you're GM tech as to what to do. That's why you're paying 1000 bucs
10-03-2013, 06:43 PM | #14 | |
The kit will be similar to this: http://www.rostra.com/manuals/250-7610_Form5383A.pdf |
