04-24-2011, 12:19 PM | #1 |
Drives: 2010 SS Join Date: Nov 2009
X2 and X3 install instructions
Anyone out there have the install instructions for the X2 and X3 wiring harness? I recieved the kit from ******** and either did not get them or misplaced them. I Got them now.
I have the old X3 harness and need to hook up the rca's as well, so if anyone knows which wires to solder that would be a big help. I've got the wire pairs figured out (red & blk w stripe and yellow & brwn w stripe) but not sure which wire goes on the center/outside post of the rca, or if it matters. Any help would be greatly appreciated. Last edited by BUMBLE-B-TUNA; 04-25-2011 at 10:14 AM. |
04-24-2011, 01:31 PM | #2 | |
Drives: 2016 Garnet Red 1SS Join Date: Feb 2011
Here you go. Shouldn't be any need to solder.
04-24-2011, 02:32 PM | #3 |
I now have the instructions thanks to a friendly C5 member!. All I need now is some info on soldering the 2 rca connectors onto the spare wires. I have the old harness with just 2 rca connectors and need the additional 2 connected before I can proceed. Like I said before, I have the wire pairs identified, I just need to know which wire goes on which post of the rca (center or outside) or if it matters.
04-25-2011, 10:17 AM | #4 |
If anyone has the NEW harness in hand and could just unscrew the rca connectors to identify the wire colours, thats all I need. Please, Please, Please!!!
04-25-2011, 11:16 AM | #5 |
CAPTIAN CAMARO
I got the harness and installed my amp the amp started to smoke. I dont know why? everything was connected right
CAPTAIN CAMARO
04-25-2011, 11:19 AM | #6 |
Well that sucks, sorry to hear. Hope I have better luck if/when I figure out the rca wiring.
04-25-2011, 11:24 AM | #7 |
CAPTIAN CAMARO
I have the x3 . im going to try it again with a different amp to see what happends. What amp are u using
CAPTAIN CAMARO
04-25-2011, 11:38 AM | #8 |
I'm using an old Alpine V-Power 75w x4.
04-25-2011, 01:11 PM | #9 |
Drives: 2010 SS/RS Join Date: Mar 2011
Was the power (+12v) connected before the connectors? Meaning was the main power connected first and then it smoked after you hooked the line levels in and speaker outs? Usually an amp smokes when you reverse the + and - main power input. I would be exceptionally leery of connecting a second amp in your case. Most places won't take back a smoked amp.
Both my rides will smoke ya 2010 L99 2SS/RS - Hertz HE HSK 165 components/PPI A404 & A600/JL Audio 10W6/Audio Control EQX, FAST Intake Manifold
04-25-2011, 01:33 PM | #10 |
CAPTIAN CAMARO
I connected the harness to the BA amp and then I connected my rockford amp to power my sub. The sub worked then the rockford amp started smoking and the sub still worked. I try the amp in my other car amp still works , no smoke come out . So I dont know why it did that in the camaro
CAPTAIN CAMARO
04-25-2011, 01:43 PM | #11 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
You probably need a ground loop isolator to remove the dc in the line.
04-25-2011, 01:53 PM | #12 |
CAPTIAN CAMARO
Ok so how do I do that and were can I buy what I need. Because my understanding was all I needed was the x3 harness to put my sub in the car
CAPTAIN CAMARO
04-25-2011, 03:26 PM | #13 |
Hey Steve, want to chime in on the rca soldering issue? You probably know right off the top of your head. I'm sitting here waiting for a response, I can't proceed without the 2 other rca's.
Thread Tools | |
