01-31-2011, 07:44 PM | #1 |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
Spoiler install??
I have a LS and want to add a factory spoiler. I have the spoiler but my body guy wants me to find a template before he will install it for me. Any idea where I could get that from?? I called a dealer and they said if I wanted a spoiler they could sell me a trunklid with the holes already in it. And when I add it what should I do for spacing so I avoid the chipping issue that factory installs have??
01-31-2011, 07:46 PM | #2 | |
Take off the carpet under the deck lid you will see holes in the lid. All you gotta do is tap a little dent in the middle of those holes and then drill them on and the spoiler should sit perfect. It's really easy. |
01-31-2011, 07:53 PM | #3 |
Banned
Oh really?? The holes are already there?? Did you drill from the bottom or top?? My spoiler is already white so maybe Ill install myself if its that easy.
01-31-2011, 08:20 PM | #4 | |
Drives: 2010 IOM 2LT 334HP Join Date: Feb 2010
This!! I helped a friend do his. Just make sure you use some touch up paint to put in the holes after you drill through. Good place for rust to start if you don't.
01-31-2011, 08:50 PM | #5 |
We drilled from the top down and yes make sure you put something because that bare metal will rust.
01-31-2011, 10:39 PM | #6 |
Drives: still saving! Join Date: Feb 2010
02-02-2011, 02:15 PM | #7 |
Banned
So what should I do to prevent the common issue of spoiler chipping issues??
02-02-2011, 04:04 PM | #8 |
You wanna get some locking nuts for your bolts that way your spoiler will not come loose. GM didn't do it right which caused the nut to loosen from the bolt due to vibration. I have had mine on for 7 months now and not one problem.
02-17-2011, 11:28 PM | #9 |
Banned
Do any of you guys remember the thread pitch to get to hold the spoiler on?? And what do I put under the spoiler between it and the car??
Similar Threads | ||||
How to install RKSport Spoiler? | BWProductions | Camaro DIY & HOW-TO instructions & discussions | 1 | 09-26-2010 01:28 PM |
New from RPI! 2010 Camaro Pre-Painted Body Color Rear Spoiler! $399.00, painted! | RPI Designs | Exterior Parts & Accessories | 10 | 03-25-2010 02:42 PM |
Spoiler install hose my stripes? | lostinvt | Cosmetics and Lighting Modification Discussions | 12 | 08-24-2009 02:13 PM |
DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
