Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 11-09-2013, 06:12 PM   #1
ABMLS3
ABMLS3's Avatar
Drives: 2010 Aqua Blue Camaro 2SS/RS
SS vs ZL1
After the winter I'll be camming my ss and I'm shooting for around 475-490 rwhp. I was looking up zl1 dynos and it looks like they have ~480 rwhp. Who do you think would win
Power Source Performance Turbo Kit
416 C.I ,TH400
Instagram: TomTraube
COTW ABMLS3 Build Thread
ABMLS3 is offline   Reply With Quote
Old 11-09-2013, 06:24 PM   #2
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
The ZL1
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 11-09-2013, 06:35 PM   #3
JEFF75645
Drives: his wife crazy buying mods
Originally Posted by el ess A View Post
The ZL1
Aren't they heavier than the SS?
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 11-09-2013, 06:37 PM   #4
el ess A
Older Than Dirt
el ess A's Avatar
Yes.
Old 11-09-2013, 06:40 PM   #5
LSXaddict
LSXaddict's Avatar
Drives: 1ss in Blue Ray Metallic
I'd say it depends on how the ss has its suspension set up. If the SS just spins or hops I'd give it to the zl1 but if the SS hooks and the zl1 is on stock tires I'd give it to the SS.
2013 1SS M6 with Flowmaster Pro 10 axle back and CAGS shift skip eliminator
LSXaddict is offline   Reply With Quote
Old 11-09-2013, 07:24 PM   #6
white ZL1
Drives: none
Win what?
On a road course, the ZL1 would hand you your ass.
On a drag strip, I suppose it depends on whether we're talking A6's or M6's, what tire each car is on, and each driver's ability.
white ZL1 is offline   Reply With Quote
Old 11-09-2013, 08:13 PM   #7
Blueclyde
Drives: 2023 ZLE
I had a 482 rwhp head cam SS. It was an awesome car. My opinion is camming these LS3's has it's trade offs. They make great power over 3000 rpm. They lack torque down low to get the car moving. They actually lose a little low end torque when cammed.
My ZL1 is bone stock and there is no question that it's faster than my SS was, in a straight line. It's not a ton faster, but it's faster. They are totally different cars. That's no slam on the SS. I think the SS is an awesome car.
Blueclyde is offline   Reply With Quote
Old 11-09-2013, 08:15 PM   #8
Blueclyde
Drives: 2023 ZLE
Also, many M6 ZL1's dyno just over 500rwhp.
Old 11-09-2013, 08:16 PM   #9
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
The SS if its on tires and you can drive your aZZ off! I would have no problem with a zl1 with my little cammed ls3, but I have a th400!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 11-09-2013, 08:26 PM   #10
white ZL1
Drives: none
Careful now.
An A6 ZL1 is a cold air and a tire from putting a car on you at the stripe.
Old 11-09-2013, 08:37 PM   #11
Emvici
Drives: 2014 ZL1 White Convertible
If you can get in the 480 rwhp range, then you have just managed to get as much Hp as the ZL1 motor has, and you matched it without a supercharger and by just adding a Cam. Gee why couldnt GM have just thought of that?? If you can get 160 hp gain by adding a just a cam wow. Is it possible to do by simply just adding a cam?.
Emvici is offline   Reply With Quote
Old 11-09-2013, 08:39 PM   #12
white ZL1
Drives: none
Originally Posted by Emvici View Post
If you can get in th e 480 rwhp range, then you have just managed to get as much Hp as the ZL1 motor has, and you think you can match it without a supercharger and by just adding a Cam???? gee why couldnt GM have just thought of that?? I think its because You cant go from 320 rwhp (stock ss) to 480 rwhp by just adding a cam. gee if you can get 160 hp gain by adding a just a cam wow. alot of work went into the zl1 motor to get and maintain 480 rwhp, if it were only so simple to just add a cam.
Read the OP's sig, and re-think what you just typed.
You'll either realize you were wrong, or you don't know much about these cars.
Old 11-09-2013, 08:42 PM   #13
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
If you read the OP's post you'll see his modification list. So yes, he's a cam away from being near his goal.
Deftones is offline   Reply With Quote
Old 11-09-2013, 10:34 PM   #14
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
Adding a decent cam package to a LS3 (M6) SS along with full bolt-on's and a professional tune will net you 500whp. A L99 (A6) your looking at 470-480whp..
A cam install alone will not work, especially if you don't have the support modds..
Remember that raw numbers are only part of the equation. The ZL1 is heavier but the suspension is vastly superior to a stock SS. There are plenty of cammed SS's beating stock ZL1's but they have at least upgraded their suspension, tune, bolt-ons, cam and of course tires...
alaskacamaro is offline   Reply With Quote
