Old 01-11-2018, 12:31 PM   #1
rviper24
rviper24's Avatar
Drives: 2013 Camaro SS 6-Speed
BMR Spring Options
I'm sure this has been brought up before but I've been shopping around for the bmr drop springs. I originally was going to go with 1.4'' all around but started to worry the rear was going to look lower than the front with an even drop. So I looked into the 1.25'' drop for the rear so it would be 1.4'' in the front and 1.25'' in the rear. Has anyone done this setup? Any input is much appreciated!
If you have pics of your camaro dropped 1.4'' or 1.4''x1.25'' please post below!!!
2013 Camaro 1SS 6-Speed LS3
All stock.. For now...
rviper24 is offline   Reply With Quote
Old 01-11-2018, 01:16 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
The rear already sits higher than the front so wouldn't you want to do 1.25" front and 1.4" rear? I went with Eibach Pro-Kit springs which are 1.0" front and 1.3" rear which more or less evens out the ride height front to back.
Edit: if memory serves, BMR has 1.0" springs as well, so you could maybe do 1.0" front and 1.25" rear if you're looking to even out ride height.
KillboyPowerhead is offline   Reply With Quote
bmr, bmr 1.4
