Old 07-30-2014, 10:18 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Smile Adding more cameras To your Mylink.
So we think we have a way to add more then one camera on the the touch screen Mylink radios, Will try to test over the week end if it works we can have 3 cameras in the car, "only one at a time" for now,but you can have 2 cameras and a DVD/blue ray or any combo you like.
It will not be a lot of cash to do this mod, if you can solder you can do this, we know there are units out there that can be added for a lot more, that can Bluetooth the date to the unit and in to the screen, this will be a hard wire job for the DIY guy.
P.S if you cant solder we can send you the new wires.
P.S.S. if any one with the 2010 M6 V8 cars that the camera does not work till your moving, this will fix that if it works.
Old 07-31-2014, 02:11 PM   #2
k818mn1
Drives: 2016 Camaro SS, Garnet Red
This will be great. I need a front curb camera - my curb-alert has never been 100% reliable and quit altogether recently. I'm assuming there will need to be a switch to select the second camera on the display.
k818mn1 is offline   Reply With Quote
Old 08-02-2014, 01:42 PM   #3
Ayuir
Army EOD Tech
Ayuir's Avatar
Drives: 2014 BRM 2SS/RS
Subscribed.
Ayuir is offline   Reply With Quote
Old 08-02-2014, 02:03 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I'd like to see this..
Mods:
Old 08-02-2014, 07:58 PM   #5
camaro-ss65
camaro-ss65's Avatar
Drives: Camaro 2SS 1LE
this has been done already...
http://www.camaro5.com/forums/showth...=360514&page=2
2014 Camaro 2SS 1LE CRT - RS - Recaros - NPP - Sunroof - Nav
camaro-ss65 is offline   Reply With Quote
Old 08-03-2014, 08:08 AM   #6
2SSRS@Gen5diy
Originally Posted by camaro-ss65 View Post
That is good work, but i am working on adding more then the front camera it will have up to 3 inputs so you can run a DVD if you like.
Old 08-03-2014, 08:19 AM   #7
2SSRS@Gen5diy
pic of 3 input video.
Old 08-03-2014, 12:27 PM   #8
twentytwelvebee
twentytwelvebee's Avatar
Drives: 2012/2ss "transformers edition"
subscribed
twentytwelvebee is offline   Reply With Quote
Old 08-04-2014, 09:15 PM   #9
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
For sale yet? How do you change inputs?
Rainbow1616 is offline   Reply With Quote
Old 08-05-2014, 11:40 AM   #10
Deam0n
Drives: 2018 Camaro 2SS (European Version)
Subscribed..
Deam0n is offline   Reply With Quote
Old 08-05-2014, 07:52 PM   #11
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
Waiting for your results! Great work Ofer, keep them coming!
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 08-06-2014, 11:18 AM   #12
TofuDragon
TofuDragon's Avatar
Drives: 2010 2LT RS M6
Did you get this working, Ofer? I was trying to do this (add switchable front camera) after installing the Mylink upgrade a few months ago. Only one Camaro5 user seems to have figured out how to get the Mylink camera to turn on without being in reverse in this thread:
http://www.camaro5.com/forums/showthread.php?t=360514
64stingray added it to his ZL1, but I couldn't figure out how to duplicate his method on a v6.
It's easy enough to add video inputs to other aftermarket headunits since they have switchable video signal, but the issue is Mylink.
When I tried it, I hooked up a front camera and can get it to show up on either my rearview mirror or Mylink with switches, but only if car is in R. If you've figured out an easy way to get the Mylink screen to show a video feed at the flip of a switch without being in REVERSE (or by faking a reverse signal), that'd be awesome and all I'd need. I already have a video amplifier unit with 2in/6out (too many outputs, but should work too)
http://www.autotoys.com/pics/pacvideoamp1.jpg
Self-installed all mods with help from Camaro5 forums! HUD, Front & Rear View Cameras, VMax Ported Throttle Body, Vararam Intake, VMax Black ICE-olater, Eibach Front Sway Bar, Extended Vinyl Stripes
TofuDragon is offline   Reply With Quote
Old 08-07-2014, 11:36 PM   #13
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I'd be happy with just a back up camera... I can solder.
Jason@JacFab is offline   Reply With Quote
Old 08-08-2014, 04:51 AM   #14
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
Would be good if you could set it up to record while your driving, for insurance purposes.
45thCamaro is offline   Reply With Quote
backup camera, dvd, front camera, movies, mylink
