07-10-2015, 12:33 PM | #1 |
Drives: 2010 Camaro SS 5th Gen 6spd SC Join Date: Jun 2015
SS w/ ZL1 rims either BMR 1.4" or PFADT 1.25" - Pics please!
Could a few members post pics of both. I can't decide lol
I have a SS and want to do the ZL1 replica 20x10f & 20x11r 315 tires in the rear. Please let me know if I have any rubbing issues. Thanks |
07-11-2015, 02:39 PM | #2 |
Anyone? Specifically ones with that rim/tire setup
07-12-2015, 11:47 AM | #3 |
ZL wheels are the same as 1LE arent they? If so, check out that thread. 1LE models lowered. Some people have complained of rubbing with 315 in the rear, while others have not. It is probably very close either way and may depend upon how much the springs settle or how the car sits from the factory.
http://www.camaro5.com/forums/showthread.php?t=361590 |
07-12-2015, 03:02 PM | #4 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
BMR setup 1.4 rear 1.25 front, no rubbing issues. Wheels are 20x10 square setup 275/40
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
07-12-2015, 10:50 PM | #5 |
I have this exact setup let me find a pic
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
07-12-2015, 11:43 PM | #6 | |
'It's an experiment'
-Don
747 RWHP 794 RWTQ
07-13-2015, 12:34 AM | #7 |
Thanks Don! Appreciate it and all you have done to help me out! Sent from my iPhone using Tapatalk
07-13-2015, 10:04 AM | #8 |
I want almost no wheel gap. 1.4" probably the way to go huh?
07-13-2015, 10:25 AM | #9 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
Pfadt springs. 285/35ZR20's on all four corners.
07-13-2015, 03:48 PM | #10 |
man is it hard to make a decision between these two springs lol...
I just want to do it right the first time The more photos the better lol |
07-13-2015, 08:05 PM | #11 |
I wouldn't go any lower than 1.25. Keep in mind the 1LE/ZL1 wheels and tires are shorter than the stock Pirellis, plus if you add long tube headers you're pretty close to the ground.
07-14-2015, 08:33 AM | #12 | |
So your saying the wheel gap will be barely their with a 1.25" drop? I think I will need to swap out the front tires with 275/40 for the 10" ZL1 replica rims. I just don't want to regret it having to much of a wheel gap...? |
07-14-2015, 12:21 PM | #13 | |
07-14-2015, 12:25 PM | #14 |
Also if you're running the 10" wheels up front you should run 285/35's... our heavy cars need all the tire they can get up front.
