06-25-2012, 03:26 PM | #1 |
Drives: '10 Blk Camaro SS/'08 Blk Silverado Join Date: Feb 2011
Removing Cowl grill
trying to see if there is any problems removing the washer blade/arms from the cowl grill as I want to hydrodip my cowl.Will the arms just slide off after removing the nut or is there a special tool to pull them off?
anyone done this already...? Thanks for the help/info... |
06-26-2012, 08:37 AM | #2 |
Drives: SS camaro Join Date: Apr 2011
The arms will give you a bit of a problem but with a little twisting they will come off pretty easy after the nut is removed.
06-26-2012, 03:24 PM | #3 |
Thanks, what i needed to know
06-26-2012, 06:23 PM | #4 |
LS1 to a LS2 to a LS3
Drives: 2011 Camaro 2SS/RS IBM Join Date: Apr 2008
Those wipers arms are a total paint to remove. I found by kinda pushing in the middle of the arm, it takes some of the tension away and it makes it eaiser to remove.
08-14-2012, 11:04 AM | #5 |
LED god
Drives: 2010 Inferno Orange Camaro SS/RS Join Date: Oct 2010
Took off bolts, twisted pried and pulled for 5 min. No luck, not a mm. I drive a early 2010 and have never been off. Any suggestions? Gonna buy a battery terminal puller today. I did all this on the one I could reach, the other...
Thanks in advance
