Old 11-11-2010, 06:45 PM   #1
MAZZ77X
www.njminigp.com
Drives: 2010 IOM SS M6
2010 Clutch Sucks
I love just about everything about my new SS but the clutch pedal feel down right sucks! The cam like feel is about as bad as they could make it. It pops out at just the wrong time making the car very hard to drive at a normal speed. Now when jamming through gears it's not a big deal but around town driving is tough and annoying to say the least.
Is there any way to fix or ease this issue?
P.S. the drivers side mirror is terrible with the beveled edge distorting the view. Aside from these two things the car is a winner in every way.
MAZZ77X is offline   Reply With Quote
Old 11-11-2010, 06:49 PM   #2
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Buy a new clutch and pressure plate and install one of these...
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 11-11-2010, 06:50 PM   #3
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
LMAO...
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 11-11-2010, 07:23 PM   #4
mbspeed
mbspeed's Avatar
Drives: 2015 CAMARO SS LS3
check your master cylinder my ss had clutch problems when i took it to dealer he found fluid was bad and needed to be flushed out causing clutch problems
mbspeed is offline   Reply With Quote
Old 11-11-2010, 10:00 PM   #5
monstertodd
monstertodd's Avatar
I don't know, my clutch is probably a little tighter than other cars I have driven, but it feels just fine to me. 71XX miles and counting.
Old 11-11-2010, 10:04 PM   #6
Huck1974
Drives: 2011 2SS
The clutch is a downgrade from the vette. Probably that way on purpose so we don't break half shafts.
Huck1974 is offline   Reply With Quote
Old 11-11-2010, 10:05 PM   #7
midnighter
Drives: nothing
Trade for one with an L99.
Old 11-11-2010, 10:55 PM   #8
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Take it to the dealer. Let them drive it. There's a lot of people who complain about the clutch when there are really no problems at all. Take it to the dealer first before doing anything drastic.
Regarding the mirror, you will get used to it.
Old 11-12-2010, 01:41 AM   #9
Heelhook22
Heelhook22's Avatar
Drives: 2010 Black SS
Had same problem with my clutch sticking. Took it to the dealer in March. They replaced everything and clutch was driving fine until the past 2 weeks. It appears that the cold weather has something to do with it as every morning I have to lift the clutch pedal off the floor to bring it back to its proper position. Takes a while it seems to "warm up" before it starts engaging normally.
I think I've decided I want an aftermarket clutch, but don't want to shell out the extra money if it won't solve the problem.
Heelhook22 is offline   Reply With Quote
Old 11-12-2010, 06:47 AM   #10
John Deere Boy
I bleed green
John Deere Boy's Avatar
Drives: '11 2SS/RS LS3
I agree with you about the cam-like feel. When i test drove one i absolutely hated it.
John Deere Boy is offline   Reply With Quote
Old 11-12-2010, 07:27 AM   #11
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
You didn't happen to be one of the people that decided to take off the return spring were you?
To the OP...
Really there are only 3 options:
1- replace it with something you like
2- get used to it
3- don't drive something with a clutch
TommyTSquared is offline   Reply With Quote
Old 11-13-2010, 08:39 AM   #12
MAZZ77X
www.njminigp.com
Just to be clear, the clutch itself is fine. I just hate the cam like feel when the pedal comes off the floor. It seems to spring back just as it's engaging causing a rough/jerky grab, if that makes sense. It can be driven smooth but requires a lot more effort than anything I have ever drove before, even 9 sec race cars.
To the poster who commented about the return spring, please explain what this is and what it does??? I am the second owner but the car was like new when I bought it (810 miles).
2010 SS Inferno Orange 6 speed.
Old 11-14-2010, 07:05 PM   #13
Lord Grey
Lord Grey's Avatar
Drives: 2010 Camaro SS/RS
I had the same problem with my SS, from day one. After putting up with the problem for nine months, I finally took it to a dealer. They eventually found out that the slave cylinder had an internal leak, and replaced it. The clutch feel is great now -- no bizarre springiness.
Note that the dealer initially thought that there was no problem with the clutch. I had to convince the service manager to do something, and he opted for a TSB involving re-torquing the clutch plate bolts. They found the leak only after dropping the transmission to re-torque those bolts.
Lord Grey is offline   Reply With Quote
Old 11-23-2010, 08:06 PM   #14
TURBOJ
TURBOJ's Avatar
Drives: 2011 2SS/RS, 1998 Z28
This one??
http://www.camaro5.com/forums/showpo...0&postcount=17
TURBOJ is offline   Reply With Quote
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
Must post picture of a Chevy to win. "prima"Donna Off-topic Discussions 74976 09-13-2013 11:33 PM
Camaro 2010 Issues Tim's.2010.Camaro.SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 57 06-04-2010 09:27 AM
Edmunds: 2010 Ford Mustang First Look Scotsman General Automotive + Other Cars Discussion 32 11-23-2008 09:55 PM
