11-27-2010, 10:59 AM | #1 |
Drives: 2011 SS Join Date: Oct 2010
Looking to do gears cant decide 3:73 or 4:10
The Camaro seriously needs new gears because its so heavy and hard to get the most out of the powerband.
I want more jump off the line and midrange but I dont want nasty noise and whine or be over reved at highway speeds. I tend to cruise now on the highway in 4th gear mostly and then 5th at speeds of 80-105MPH Can owners of both sets of gears comment on how their cars feel, any increased noise or feedback associated with the swap? Its costly and expensive and I want to do it only 1 time. Car is street driven and will get a supercharger after the new year. I had 4:11 in an older Mustang and it was brutal on the highway and I do not want that. |
11-27-2010, 11:12 AM | #2 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Two words...Torque converter
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
11-27-2010, 11:14 AM | #3 |
Drives: 2010 Camaro Join Date: Feb 2010
Do both!
11-27-2010, 11:18 AM | #4 | |
11-27-2010, 11:18 AM | #5 |
Car is a manual I wish I could afford to try both out but no dice this time of year.
Supercharged SS your car is pretty wild how does it cruise at 90 and what RPM is it at? |
11-27-2010, 11:20 AM | #6 | |
Yeah i dont even know who to go to for the set up of the gears. I have read on the forum some guys have bad whine, others have blown gears etc. I just want something comparable to the 3:45 just with more fun. I do plan to do a blower in the spring so you suggest the 3:73? Is the 4:10 just too extreme for a blown car? |
11-27-2010, 11:24 AM | #7 |
With the stock 3.45s you would cruise at just under 2100RPM at 90MPH in 6th gear. Going to 3.73s would put you at 2250RPM. 4.10s would put you at just under 2500RPM. The 6th gear really helps make things more liveable.
11-27-2010, 11:28 AM | #8 | |
11-27-2010, 11:32 AM | #9 | |
I drove a new GT 5.0 one of my neighbors picked it up and I like the off the line respone it had, the car felt much livelier with the SVT 373 gears. from my test drive that Mustang felt much faster than my Camaro by a good margin. |
11-27-2010, 11:33 AM | #10 |
Apex if I did 373 or 410 what would my RPM be in 4th gear and 5th at 80-95mph?
11-27-2010, 11:39 AM | #11 | |
11-27-2010, 11:47 AM | #12 |
11-30-2010, 08:55 AM | #13 |
I was in the same situation a few months ago. I also recieved some great feedback from Apex Chase.. I have a 427 - 675 HP engine swapped into my M6 and decided on the 3:73 set up. Glad I did, I can barely keep it on the road with traction control off in 1st and second, it eliminated alot of the lurching that the engine was looking for with the tall 3:45's in it previously
I have put on about a 800 miles on highway as well and the RPM's in 6th cruising only went up about 200. If you are keeping it stock, go 4:10, if you are supercharging it, I think 4:10 would be too aggressive for what your looking for, especially if it is a daily driver. My 2 cents. |
11-30-2010, 12:32 PM | #14 | |
Similar Threads | ||||
Swap v6 rearend for a v8 rearend lower gears | dcmock | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 14 | 11-28-2010 09:18 PM |
UPGRADE: Gears or Clutch | calbert1999 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 8 | 11-10-2010 10:05 AM |
Anyone with BIG HP do GEARS??? | jrpxxii | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 10 | 03-28-2010 09:07 PM |
373 gears!!! | CaptianSam | Camaro Price | Ordering | Tracking | Dealers Discussions | 43 | 03-25-2009 05:19 AM |
SS chirp gears? | CamaroEnergy4Life | 5th Gen Camaro SS LS LT General Discussions | 46 | 03-08-2009 07:42 PM |
