Old 04-05-2015, 06:47 PM   #1
skysharker1
Airborne Paratroopers!!!
skysharker1's Avatar
Drives: 2016 Camaro SS Convertible
Location: Mid-NJ.....13 Year Army Paratrooper. Death from Above!!!
Send a message via AIM to skysharker1 Send a message via Yahoo to skysharker1
Car will not start....no power
Need some help....please!!! Has anyone had an issue with their car not starting? I have power when I first turn the key, dash lights up and radio turns on, but when I go to start it I lose all power and nothing happens...not even a crank.
This happened to me about 2 years ago...and when it got towed to the dealer it started right up...of course!
skysharker1 is offline   Reply With Quote
Old 04-05-2015, 08:03 PM   #2
MD LF SS
MD LF SS's Avatar
Drives: 2010 IOM 2SS/RS
I had something similar just happen. Ended up being main cable loose at fuse box.
Sent from my AGM 2013 SS/RS
MD LF SS is offline   Reply With Quote
Old 04-05-2015, 08:06 PM   #3
skysharker1
Thank you!! Which fuse box?
Old 04-05-2015, 08:07 PM   #4
MD LF SS
MD LF SS's Avatar
Main box front passenger side under hood
Old 04-05-2015, 08:12 PM   #5
skysharker1
K thanks....I'll check it out
Old 04-05-2015, 08:31 PM   #6
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
Do you have the 4 pack? If so what does he voltage gauge read? Maybe you need to charge your battery? How long has it sat for?
45thCamaro is offline   Reply With Quote
Old 04-05-2015, 08:40 PM   #7
skysharker1
No 4 pack. I drove the car earlier today with no issues. I have 12+ volts coming from the battery. When I turn the key to the first position, everything lights up like it normally does, but when I turn the key to start the car, everything cuts off and nothing happens....the engine doesn't even turn over.
Old 04-06-2015, 05:25 AM   #8
oville-rider
oville-rider's Avatar
Drives: 2010 Camaro Summit White 2SS/RS
You could have a dead cell in the battery, 12 volt at rest but soon as you demand power it shorts out to nothing! Have your battery checked if you haven't done so yet? Maybe check your battery connection before pulling the battery. That's where I would start.
oville-rider is offline   Reply With Quote
Old 04-06-2015, 06:43 AM   #9
skysharker1
Is that something I can check, or should I take it to AutoZone or something?
Old 04-06-2015, 10:45 AM   #10
oville-rider
Do you have a volt meter and some help unless you have some long leads? Check at the battery and also check under the hood, there should be a power lead that has a red plastic cover on the drivers side. Start at the battery and work on from there. If you don't have a volt meter well then your off to the auto parts store. Good Luck!
Old 04-06-2015, 10:57 AM   #11
skysharker1
Yes....I checked under the hood yesterday and I had 12v. I will check the actual battery today.
Old 04-06-2015, 05:39 PM   #12
TooCool5
TooCool5's Avatar
^^yes do this first^^
Old 04-06-2015, 06:30 PM   #13
BALLEE
BALLEE's Avatar
Drives: 2010 2SS LS3
If it's a manual check the neutral safety switch right behind the clutch.
BALLEE is offline   Reply With Quote
Old 04-06-2015, 06:32 PM   #14
BALLEE
BALLEE's Avatar
My old camaro had the same symptoms, turned out a malfunctioning neutral safety switch
