Old 01-17-2013, 03:16 PM   #1
Cruuzin LV
Cruuzin LV's Avatar
Drives: 2012 Camaro SS 45th Anniversary
Convertible top issue? Help!?
Should the top be this loose looking? If not how do I fix it or do I need to see the dealer?
Cruuzin LV is offline   Reply With Quote
Old 01-17-2013, 03:20 PM   #2
IL-Tracker
That's why.........
IL-Tracker's Avatar
Drives: Traded a 2011 2SS/RS A6 Blk Vert
It would appear the 5th bow is broken. That is exactly how mine looked prior to getting it replaced. Should be covered under warranty. Bring it back to the dealer as soon as you can. A fairly common problem. Sorry.
Mike
IL-Tracker is offline   Reply With Quote
Old 01-17-2013, 03:25 PM   #3
Cruuzin LV
Cruuzin LV's Avatar
5th bow broken
Mike
Thanks man! Yeah shes only got 14k miles on her. hopfully these pictures will help other vert owners in the future.
Old 01-17-2013, 03:27 PM   #4
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
what is your build date Cruuzin LV?
it's on the sticker on the inner drivers door jam..
someone here was keeping track of the build dates to see the most affected people, as there was some type of change in the top mid build for 2012.
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 01-17-2013, 03:49 PM   #5
Cruuzin LV
Cruuzin LV's Avatar
8/11
Old 01-17-2013, 03:51 PM   #6
IL-Tracker
That's why.........
IL-Tracker's Avatar
Cruuzin -
Another suggestion - don't know how long the top has been in that condition, but with mine, it went almost a year and close to 7K before I got it fixed. In that time, the dealer said the damage was beginning to wear into the water management bag, so that got replaced along with the 5th bow. Try to minimize the cycling of the top until you can get this fixed, and make sure they closely inspect the water management bag for damage as well.
Good Luck - enjoy your car - sometimes I wish we still had ours - but it was an obsession.
Old 01-17-2013, 03:56 PM   #7
Cruuzin LV
Cruuzin LV's Avatar
Cruuzin -
It happened last night. I had a large box in the backseat so I lowered it to get it out and when I put the top back up I heard a pop noise and thought nothing of it. Then I noticed it today. Going to take it in today.
Old 01-17-2013, 03:56 PM   #8
Rhyder
Drives: 2012 45 Anniversary Vert
tell them to change the water bag when they replace the hood, regardless if the waterbag is damaged, they should have 0 problem doing this
Rhyder is offline   Reply With Quote
Old 01-17-2013, 03:58 PM   #9
Cruuzin LV
Cruuzin LV's Avatar
Thanks for the advice. Will do.
Old 01-17-2013, 03:59 PM   #10
'11 cyber grey vert
"SHARK" Born Apr.26,2011
'11 cyber grey vert's Avatar
Drives: 2011 CGM 2LT/RS Convertible
cruuzin,
after the 5th bow repair, keep an eye on the rear seat floors.If wet, you have a water management bag problem and/or drain tubes problem.
fyi-my water management bag was replaced about 2 months after my 5th bow broke.I asked that the bag be changed out when the 5th bow was being repaired but GM Canada would not approve it.And low and behold, 2 months later car was back in for the repair.
'11 cyber grey vert is offline   Reply With Quote
Old 01-17-2013, 04:31 PM   #11
Cruuzin LV
Cruuzin LV's Avatar
Hopefully this doesn't become a nightmare situation but I'm staying positive. I'll keep you guys posted.
Old 01-17-2013, 04:37 PM   #12
'11 cyber grey vert
cruuzin,
good luck!!! hope all goes well...
on a positive note:a little history on mine..my 5th bow broke at about 2600 miles and now have about 7000 miles...seems the repaired 5th bow is holding up so far and the seal at the trunk is much less noticeable after the repair than how it was off the assembly line.
Old 01-17-2013, 05:34 PM   #13
Cruuzin LV
Cruuzin LV's Avatar
Originally Posted by '11 cyber grey vert View Post
cruuzin,
I don't know how you roll in Canada but we keep our seals in the zoo not in our trunk!
I'm sure it will turn out just fine.
Old 01-17-2013, 06:49 PM   #14
rangomr
rangomr's Avatar
Drives: Oracle Camaro has all the bells &
: laughabove:
rangomr is offline   Reply With Quote
