07-28-2013, 01:22 AM | #1 |
Drives: MANual Join Date: Jul 2013
Straight Piped LS3...Resonator Delete?
So I have a 2011 Camaro SS manual transmission and it has the mufflers removed. It sounds good but not too loud. I don't plan on doing anything expensive to exhaust anytime soon. I know headers but not now.
What I want to know is what will happen if I remove the resonator on my straightpiped camaro? 1) Will it make a big difference in sound? ie: loudness and tone (MAIN QUESTION) 2) Will it decrease performance? Is this called true dual? Thanks.. |
07-28-2013, 01:50 AM | #2 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
You need to leave a crossover pipe of some sort inline. It's been proven that you'll lose HP and Tq if you go true straight pipes. OEM is a H pipe but most go X pipe when they upgrade the exhaust. Either is fine as long as you have one.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-28-2013, 01:52 AM | #3 |
So does taking off resonator get the h-pipe taken off too? Also, why do they upgrade to xpipe?
07-28-2013, 02:21 AM | #4 |
Search Ninja
If you have a A6, the resonator section has the H pipe within it. If you have a M6, you can cut the resonators out and still leave the H pipe. You can't miss it. It's the only part of the exhaust where they two sides merge. It's right behind the resonators. As for why they change to a X pipe is purely preference and availability. X pipes are all over the place and they have a little more "exotic" sound, over a classic H pipe.
07-28-2013, 02:45 AM | #5 |
Drives: '11 Cammed LS3, '14 Scion FRS Join Date: Dec 2011
Whenever I hear a car without resonators the raspiness hurts my ears because it sounds so terrible. That's why I still have the stock ones even though I have no cats or mufflers. Much cleaner sound.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP |
07-28-2013, 03:06 AM | #6 |
Ok thanks for all the info but I'm still unclear about something. Is removing the resonator worth it? Like will it make it a lot louder? (M6)
07-28-2013, 01:14 PM | #7 |
07-28-2013, 01:18 PM | #8 |
Drives: 2010 Summit White Camaro SS/RS Join Date: Dec 2010
I have a straight piped, stock exhaust on my Camaro, and it sounds good to me! I always have people ask me when exhaust or what cam I have in my car, and I chuckle when I say "It's the stock exhaust" And About losing power, I have a Centrifugal S/C, and I don't believe having straight pipes decreased any power...
07-28-2013, 01:30 PM | #9 | |
07-28-2013, 01:48 PM | #10 |
Drives: Camaro Join Date: Dec 2012
07-28-2013, 01:54 PM | #11 |
Drives: 2013 silver ice metallic ZL1 Join Date: Jan 2013
Just remove the H pipe and resonators and get this: http://www.ebay.com/itm/111059722231...84.m1497.l2649
Just installed it on my car; sounds great. I have Borla S type also though. |
07-28-2013, 11:52 PM | #12 | |
07-29-2013, 12:34 AM | #13 |
I didn't actually know magnaflow made on for the camaro. Are you speaking of the universal X pipe? The one I linked to you is made specifically for the Camaro and is a direct replacement. On the L99 you just cut the stock resonator off directly in front and behind it and clamp the X-pipe on. You can get the aluminized steel one from jegs for $99
07-29-2013, 12:42 AM | #14 |
oh. so will doing this make my camaro a lot louder?
