02-08-2020, 05:35 AM | #1 |
Drives: 2016 Nightfall Gray 2SS Join Date: Jun 2018
LT4 swap, E85 on stock fuel system in an SS?
Hey guys. Will the stock fuel system be able to handle running a stock LT4 (stock pulleys) AND E85? Not looking to boost past stock and I'm about to start the swap. I want this thing to survive a 500 mile roadtrip out to the roadcourse, a 3 day track event and the drive back.
Maybe a mix of E85 and pump 93? Curious where the limit would be vs ethanol content if anyone knows. Cheers, Pete |
02-08-2020, 07:13 AM | #2 |
Drives: 2018 2ss 1le Join Date: Jan 2018
im guessing no way fuel system keeps up with that, and if it does you will be at the limit which is never a good idea...
getting it tuned right?
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
02-08-2020, 07:43 AM | #3 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Adding a PD blower will max out an LT1 fuel system on 93, nevermind E85. Adding the LT4 fuel system will let you run some E, but probably just a blend of somewhere in the E30-E40 range if you’re staying at low boost.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
02-08-2020, 08:01 AM | #4 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
Looks like a bad idea to me. LT1 fuel sometimes cannot even keep up with a base kit on pump E10, and the LT4 pullies that you are using might mean 10~11psi of boost. At least I think that is what ZL1 guys say? WAY too much for stock fuel in my opinion, then E85 makes it even more ridiculous. I also think that running this much boost on a stock LT1 for a 3 day road course event will be pretty risky. These things don't like heat and you'll build plenty of it doing that kind of driving.
02-08-2020, 10:42 AM | #5 | |
Thanks for the input guys! |
02-08-2020, 12:06 PM | #6 |
The LT4 has a lower compression ratio, and therefore it needs more boost than an LT1 would to make the same power. So while the base sc kits made for an LT1 motor probably would be in the 6~8psi range, I don't believe that's the case for the factory LT4 pullies. You could try finding out what pullies ADM or Weapon-X use when they put an LT4's blower onto a stock LT1 motor to get the 6-7psi of boost that you wanted.
02-08-2020, 06:00 PM | #7 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I think that the stock Pulley on the LT4's blower unit provides ~ 9 PSI boost. If ignition timing is not advanced too far, then 93 pump can be made to work pretty safe ~ 550 RWHP.
There are a bunch of tuners here with a lot of experience on this setup and can comment on the safe limits on the LT1 stock motor for your planned application. Adding the LT4 fueling components would be another recommended safety measure. |
02-08-2020, 06:31 PM | #8 |
Drives: SS 6 speed of course Join Date: Jan 2016
second hand lt4 pump and lt4 injectors, lt4 low side pump are minimum upgrades IMO if you are going to tune for E.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
02-10-2020, 10:11 AM | #9 |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
If you have the LT4 fuel parts and a DSX lowside or boosta pump. you can tune probably on E50. but never full e85. you will be constantly keeping up with how much e you put in.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber |
02-10-2020, 11:04 AM | #10 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
You need LT4 fuel system to run E85. At 5psi you can likely run full E85, at the 8-9psi you will be limited to E50- E60 which is all you need to get the benefits of E anyway.
ADM performance has a lot of info on the topic. https://www.camaro6.com/forums/showthread.php?t=528126 https://www.camaro6.com/forums/showthread.php?t=527512 https://www.camaro6.com/forums/showthread.php?t=475479 https://www.camaro6.com/forums/showthread.php?t=444241
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
02-10-2020, 11:49 AM | #11 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I even made an Excell spreadsheet to calculate it for me. As far as the LT4 supercharger on a LT1, you are going to be maxed on the LT1 fuel system on 91/93 octane. If you want to run E85 at all you will need the full LT4 fuel system and the fuel lines. Even then the max you will be able to run is around E40-E55 depending on who tunes the car for you.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
02-10-2020, 12:37 PM | #12 |
It depends on the boost level...with the stock LT4 pulley(9psi), yes I agree, however you can run a larger pulley. ADM was able to run full pump E85 with 2.9 pulley(5-6psi) with the LT4 supercharger and fuel system on a 1LE. First link I posted
OP would be better off to run the larger pulley and E85. It produces a better power curve and less heat. Also no need to worry about mixing formulas, just pump and go. It makes better power and less heat then the stock pulley on 93.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 02-10-2020 at 12:51 PM. |
02-19-2020, 08:28 AM | #13 | |
YOU CAN NOT!!!!! RUN BOOST AND E-85 ON LT1 FUEL SYSTEM. You should not even consider a blower and E without also including a ZL-1 in tank pump LT4 high pressure pump, and LT4 injectors. Ted.
www.jannettyracing.com
02-19-2020, 08:33 AM | #14 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
OP don't go the cheap way out, many of us have learned the hard way. Do your research on the pros and cons of boosting an LT1 and or the issues LT4 owners have ran across throughout these years. It took me a whole year after doing research to finally start my install of my boosted parts. their is many many things out there you will need for your car for it to run properly. Throw a cheap build at it and get a cheap return out of it. I also use the term "cheap" lightly.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
