JUICEDMOTORSPORTS
Old 03-27-2013, 07:56 PM   #1
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
front sway bar removed
Who runing the 1/4 with the front sway bar removed ? And how much did it help on the launch ?
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 03-28-2013, 12:01 AM   #2
Supercharged SS
Drives: 2010 Camaro
On my car removing the front sway was only good for some shitty highway driving!! It was cutting mid 1.4's before we took it out and it has never improved. I'm actually thinking about putting one back in since I plan to use the car on the street more this year.
Old 03-29-2013, 11:23 AM   #3
Mr. Nasty
Mr. Nasty's Avatar
Yeah looking for some cheap help with weight transfer. With the 4l80 & 305/45/18" DR M/T i still have a lot of wheel spin. It's not a DD car but how shitty is highway driving?
Old 03-29-2013, 03:11 PM   #4
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Most of the top cars on the fast list don't have a front sway bar.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 03-30-2013, 07:33 PM   #5
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Would swapping to a smaller fe2 front sway bar help with on road driving but also allow for more weight transfer?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 03-30-2013, 08:28 PM   #6
Mr. Nasty
Mr. Nasty's Avatar
Old 03-31-2013, 08:39 AM   #7
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
Just freeing up the bar in its bushings might be worth almost as much as removing the bar entirely. The bar will rotate inside them with less friction/stiction and let the nose rise just a little more freely.
Don't expect to get anywhere near the same amount of help in an IRS car that is possible in a stick axle car no matter what you do to the front bar, or from playing around with roll stiffness distribution.
Norm
Norm Peterson is offline   Reply With Quote
Old 03-31-2013, 08:45 AM   #8
Norm Peterson
The question here is did they do it because they always used to or was it the result of actual beck-to-back-to back testing?
At the pointy end of competition it makes more sense to chase even the tiny potential performance improvements. Back where the majority of us are, driver consistency is typically not good enough for the really little tweaks to matter, even though it may look good or feel good to do them.
Norm
Old 03-31-2013, 09:05 AM   #9
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i would say on the guys that r serous about their times and tryin to make the most out of the car . it probably a good thing to do . but the normal guys just hittig the track no need to. but who knows.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 03-31-2013, 10:38 AM   #10
Synner
Drives: not stock
I think its a waste with a lot of other areas to address first.
But if you really want to then just disconnect one end link bolt and zip tie it somewhere safe that won't cause interference. When you're done with the track take the one wheel off and bolt it back up. I would never drive around on the street without it.
Old 03-31-2013, 11:14 AM   #11
Mr. Nasty
Mr. Nasty's Avatar
Well am serous about my time's. Spent a lot of money on tire's & rim's on back. I would say it paid off went from 11.17 to 10.87 but the 60' was a 1.67. Still have wheel spin and that with the high 1st gear in the 4l80? Any help in the 60' should lower the top end.
Old 03-31-2013, 01:02 PM   #12
Norm Peterson
Guessing few thousandths in the 60 and 0.010 or so ET based on losing the weight of the bar up front. Don't know what letting the nose rise quicker might be worth, never tried to figure it out.
Norm
Old 03-31-2013, 07:48 PM   #13
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
This is my view......its not going to slow it down, and its another 17 lbs off the car. If it helps ok, if not, no biggie
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 03-31-2013, 10:24 PM   #14
g8lover
Drives: Pontiac G8 GT
I am interested in this topic also.... some of the guys says there is a bunch of stuff to do first but I am not sure what those things are and... i think i have done all of them. Seems disconnecting would make sense to at least try...
you could also pull timing under a "xXXx" rpm?... so you will grip and then take off... could play with that to get the traction you need... obviously if you dont need to pull timing would be better but i think not loosing it is also important.... next time out i will be disconnecting the fronts and also pulling a tad of timing under 3800rpm... hopefully will hit 9's with this setup....
good luck to you and let us know what you decide to do....
Sleeper Pontiac G8 Gt; LSX 430 with Procharger F1x ; 25psi; 4L80E conversion; Hendrix 9" rear/driveshaf; Camaro brembos; (1330rwhp
g8lover is offline   Reply With Quote
