Old 08-30-2009, 04:02 PM   #1
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
L99 Lifter noise at startup
Well I have 4k on my car and a week ago at initial start up I started getting a slight lifter tick for about 2 seconds. This happens only after sitting over night. I informed the service manager of this and his reply was these engines are notorious for being loud at startup Isn't this a new engine? Just wanted to ask around before I start pushing the issue. Its obvious the lifter/lifters are bleeding down but so soon come on. By no means do I baby my car, it is a performance car so I perform it.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 08-30-2009, 04:07 PM   #2
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
Normal to rattle a bit on startup.
patriotpa is offline   Reply With Quote
Old 08-30-2009, 04:42 PM   #3
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
So yours does as well?
11.39 @ 118 510 DA
Old 08-30-2009, 04:47 PM   #4
patriotpa
Nope, but my Silverado does sometimes when I use a crappy Fram oil filter. You could have a bad drain back valve in your oil filter. Use a Mobil1 K&N or PurolatorOne filter and see if it stops.
Old 08-30-2009, 04:51 PM   #5
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Just had the car serviced by GM so whatever they use. It did it before and after. Can't imagine a brand new motor doing this.
11.39 @ 118 510 DA
Old 08-30-2009, 04:56 PM   #6
patriotpa
Then it's just lifter noise. No big deal. It stops a few seconds after your oil pressure comes up. Perfectly normal.
Old 08-30-2009, 06:50 PM   #7
quickdraw
quickdraw's Avatar
Drives: 2010 Camaro SS/RS
Mine has done it since day 1.
2010 Yellow 2SS/RS, L99 Auto, Grey Leather, Polished 20's
quickdraw is offline   Reply With Quote
Old 08-30-2009, 07:13 PM   #8
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
Mine too. My '99 Silverado also did it.
Oldrocker is offline   Reply With Quote
Old 08-30-2009, 07:26 PM   #9
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Interesting. You would think such an advanced engine would not do this. Even if its only a few seconds its still doing some damage.
11.39 @ 118 510 DA
Old 08-30-2009, 07:31 PM   #10
camarotoofast
VIN #586 is Home
camarotoofast's Avatar
Drives: 00 Z28 Camaro 69 camaro 81 cam
Send a message via Yahoo to camarotoofast
My l99 does the liffter tap too.
VIN # 586 is home
1ss,blk/blk,poilsh rims,B.A.upgrade,a6,stainless works catback.vararam more-to-come
camarotoofast is offline   Reply With Quote
Old 08-30-2009, 07:34 PM   #11
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
I wonder if a tuner can prolong initial crank. That should solve any lifter tap. Anyone hear of this as an option?
11.39 @ 118 510 DA
Old 08-30-2009, 07:56 PM   #12
chevyss
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6
Mine started the noise just after I got it. Took it to the dealer, and they said it's normal. It does it cold and hot. It's not good when you start it up with a group of your car club and it does it. "I thought it you said that was a new car". My 07 Suburban does the same thing. The Suburban is getting so it does it longer and longer. I guess that's what they make warrenty for. It's just embarrassing for a new car.
chevyss is offline   Reply With Quote
Old 08-30-2009, 08:10 PM   #13
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Totally agree. A new car should NOT due this.
11.39 @ 118 510 DA
Old 08-30-2009, 08:18 PM   #14
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
I'm used to lifter noise, I couldn't tell you right now if mine does it. No big deal.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
lifter noise on start up with L99 djs Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 07-24-2009 01:38 PM
Lifter noise chevyss Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 07-21-2009 10:13 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
L99 Noise BLUEMARO Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 06-23-2009 05:27 PM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
