03-29-2017, 11:39 AM | #1 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
Swapping Rear Differential: Any Advice?
My new differential arrives tomorrow so I'll be embarking on swapping it out. For those how have done this any gotcha's or other advice?
03-29-2017, 05:41 PM | #2 |
Its easy. Takes an hour once in the air. Dont shortcut, you may damage an axle seal. Unbolt the driveshaft and unbolt the hubs. Slide axles out and unbolt the diff and drop it down. Reverse it going back in.
03-29-2017, 08:29 PM | #3 | |
So no need to remove the knuckles? Sent from my iPhone using Tapatalk
03-29-2017, 10:21 PM | #4 |
Knuckles/hubs what ever you want to call them.
03-29-2017, 10:32 PM | #5 |
'It's an experiment'
This may get you started on the axles:
https://m.youtube.com/watch?v=RalqfBHBU4o Or, just take the top knuckle bolt out and pull the top back: Support the knuckle.. I just did a swap, but, I have DSS axles/drive shaft http://www.camaro5.com/forums/showth...385577&page=63 -Don
747 RWHP 794 RWTQ
03-29-2017, 10:48 PM | #6 | |
Great info! Glad to see the axles can be pulled without having to remove the knuckles completely. Thanks! Sent from my iPhone using Tapatalk
03-30-2017, 09:37 PM | #7 |
Drives: 2010 2SS/RS Join Date: May 2010
This info is awesome. Doing the ZL1 diff swap in a month or 2 and this info is great. Thanks guys!
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
04-06-2017, 09:49 PM | #8 |
Replace the half shaft seals.
Even if you don't touch them at all, when you disturb 7 year old seals like those, they won't work again. At least mine didn't. |
04-07-2017, 12:45 AM | #9 |
Taking the axles out of the hubs is maybe a 3 minute job for both sides. I fought one like that. It was faster just to pull the axles out for me since it only takes a few minutes beyond that point.
