11-25-2013, 05:18 PM | #1 |
Drives: 2011 Camaro SS2/LS3 Join Date: Feb 2011
Stock LS3 Exhaust... how restrictive?
I tried a search but... yeah
I want to do some really minor, bolts ons to my LS3 in the near future. I'm thinking CAI, maybe catch can, etc. Nothing that requires a tune and stuff that I can easily take back to stock when I want to. Problem is since I want to be able to go back to stock easily, I really don't want to touch the exhaust. So the question is, is the stock LS3 exhaust that restrictive? I race this car but again, I'm not looking for 11s or anything. I'd like to be able to easily hit 12s in the car (and I'm basically there with a better launch if you look at my sig) so I don't need a ton of power. Opinions? Thanks guys!
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH |
11-25-2013, 05:30 PM | #2 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Stock exhaust isn't restrictive, just ugly and heavy. That being said, I won't be switching mine out from stock anytime soon. Get some high-flow cats and it'll open up the sound a lot.
11-25-2013, 05:33 PM | #3 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
From the cats back, not restrictive at all. The cats are most of the restriction.
Go with Solo high flow cats. No tune necessary, sound will improve immensely, and you will notice a performance increase. Best bang-for-the-buck mod ever. |
11-25-2013, 06:09 PM | #4 |
Drives: 2010 Camaro 2SS Black Join Date: Jun 2013
What size is the inlet/exhaust of the stock cat?
Will a 3" HF Cat fit without much cutting/reducing? |
11-25-2013, 06:11 PM | #5 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
I believe the stock system is a 2.5"...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
11-25-2013, 06:22 PM | #6 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
No its not. The cat back(after the cats) are 2.5" I believe but the factory cats inlet is tiny. I might have a pic still saved on my computer from when I measured and took pics. Hold on a sec I will try to find them.
11-25-2013, 06:27 PM | #7 |
As you can see its only about 2". You might not be able to tell in the pic but the inside diameter of the pipe actually reduces to about 1.8-1.9" further into the pipe. This is one reason people are able to gain 15RWHP from high flow cats alone without a tune.
11-25-2013, 06:31 PM | #8 |
If your getting high flow cats only without doing long tube headers your going to want to just get the direct fit SOLO or JBA high flow cats which are 2.5". Your not going to make anymore power with a 3" cat over a 2.5".
11-25-2013, 07:14 PM | #9 |
Drives: 2011 Camaro 2SS Join Date: Oct 2011
More restrictive than straight pipes, I know that much >
11-25-2013, 08:11 PM | #10 |
Drives: 2010 Inferno Orange SS/RS LS3 Join Date: Aug 2013
What he said.... Solos all day long. Best mod I've done.
2010 SS/RS LS3 STOCK (for now...)
11-25-2013, 08:27 PM | #11 |
Only once you pass 500rwhp is when the stock cat back becomes a real restriction.
11-25-2013, 08:39 PM | #12 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
what bo said. with a better muffler and x 2.5" will take u to 600...but u will leave a tad on the table, I know I am...but I have zero drone on the interstate, nice trade off.
-John S.
11-25-2013, 08:51 PM | #13 |
Drives: 03 vette, 94 trans am, 04 gto Join Date: Jul 2012
We actually found this out on a members car infernometallicss. He has long tubes, cold air, our cam (big) milled heads, circle d stall and at the time of test that was it. He has the no weeds cutouts w/ stock cat-back including the middle resonator. So we dyno'd it cutouts open and closed and it made roughly 30 more rwhp with them open! Now on a bolt on only car i don't think it's going to be that much at all, but start really moving some air and it does become a restriction for sure!
11-25-2013, 09:11 PM | #14 | |
30RWHP is huge. Sure would throw a wrench into the debate on weather the stock cat back is holding power back under 500RWHP.
