Old 04-01-2015, 01:56 PM   #1
Pathogen
Pathogen's Avatar
Drives: 2014 1LS Camaro
Review of CXRacing Coilovers
So, I took the plunge and picked up a set of CXRacing coilovers.
Cons:
No pillowball mounts
No camber adjustment in the top of the strut
Pros:
Easy install
30 way damper adjustment
Quality parts
Good price
In all, for about $700, you get an amazing deal for street/ strip coilovers. They are easy to install and adjust. The only issue that I had in installation is that the holes for the sway bar links were too small, so I had to drill them out. I informed the engineers at CXRacing and they should fix that issue going forward.
They ride excellently and the handling is outstanding. You use your existing top spring seats, both front and back. There is no upper camber adjustments, so those who want to really dial in their geometry should skip these.
Setting the dampers from 1-10 gives you a super-comfortable ride. 11-20 is similar to stock. 21-30 is worthy of road-course driving, but will beat you to death on regular roads. I do not feel any bounce at all.
The final review: Unless you are a hardcore racer, these are outstanding for a price point under $800.
Nobody with a good car needs to be justified. -Flannery O'Connor
Pathogen is offline   Reply With Quote
Old 04-01-2015, 02:07 PM   #2
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
Thanks for the review on the CX coil overs. Sounds to me like a great deal in quality versus price!
All The Best
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 04-23-2015, 04:48 PM   #3
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
How are these holding up, that price is very attractive
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-23-2015, 05:36 PM   #4
Orange 2010 Camaro
Cons:
Pros:
Easy install
Quality parts
Good price
Hey, your Camaro looks sick! How much did you actually lower it front & back? Also Hendricks-Engineering has a NEW product called their off-set rear differential bushings that raises the axle shafts back up where they need to be, that will prevent future problems from lowering past 1.5 in.
Orange 2010 Camaro
Old 04-23-2015, 05:51 PM   #5
Pathogen
Pathogen's Avatar
These are still performing amazingly.
I am not sure about the total amount of lowering because I went to lowering springs first.
Old 04-23-2015, 05:54 PM   #6
Zyklon-SS
Zyklon-SS's Avatar
Drives: 2010 2SS LS3
How low would these go?
Zyklon-SS is offline   Reply With Quote
Old 04-23-2015, 05:57 PM   #7
Pathogen
Pathogen's Avatar
The rear had about .5" lower to go. The fronts had about 1" left.
Old 04-23-2015, 06:06 PM   #8
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
How do you feel about the difference from lowering springs to these? The main question I have is... Going from lowering springs to the coilovers, does the lowest setting feel like lowering springs and only allow you to get stiffer? Or can you go softer like stock or softer.
Old 04-23-2015, 06:19 PM   #9
Pathogen
Pathogen's Avatar
You can completely customize the ride. These are soooo much better than lowering springs.
Old 04-24-2015, 09:25 PM   #10
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
These are made by BC.
