Gen5DIY
Old 09-10-2015, 12:53 AM   #1
1LeSS
1LeSS's Avatar
Drives: 2013 2SS/RS VR 1LE
Surging
So I have big surging when holding a high rpm. And I have surging in alot of the drivability area too.
6.2ltr, V3si tuner kit, 8.3 lb boost. What's the general conscientious say out there? Bigger blowoff valve..
Ask me questions. Gotta figure this out.
Pedderized! Lowering Springs, 32ml rear sway bar, Solid cradle bushing kit, Steel jacket radius rod bushes, JPSS caster bolt, Bo White TB, Granitelli HP coils, Apex Catchcan, Vortech V3si Supercharger, Lingenfelter ported heads, GT 12 cam and other stuff.
1LeSS is offline   Reply With Quote
Old 09-10-2015, 06:43 AM   #2
1fast
1fast's Avatar
Drives: 2010 Gen 5
When you say high rpm what is high ? and surging on normal driving tend to be fueling issue. A log file would help,
1fast is offline   Reply With Quote
Old 09-10-2015, 01:11 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Could tell a lot with a good data log.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-10-2015, 01:49 PM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
What tune are you running?
What injectors?
What fuel pump?
We typically add a second by pass valve on the same pipe to double the bypass.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
JANNETTYRACING is online now   Reply With Quote
Old 11-06-2015, 01:47 AM   #5
1LeSS
1LeSS's Avatar
the surging happens mostly during autocross. Say I stay in first gear between cones and i'm holding 4500rpm, just as i'm about to enter the next corner, the engine will surge and almost push me out of the corner. the higher the rpm, the more violent the surge. it will surge even at 3000rpm, just not as violent.
zl1 fuel pump
custom tune
63lb/hr Siemens HighZ injectors.
no data log cause the car is now parked ��
The installers are saying I need a bigger BOV. I'm running the Vortech V3si with a maxflow BOV. Vortech says that BOV is good for 1300hp, (which I do not have)
Old 11-06-2015, 09:07 AM   #6
Unreal
Drives: 2006 Z06
That BOV is more than enough for anything that blower can move IMO.
I would say tune would be first thing to look at.
Also swap to SD if possibly, works so much better for stuff like this.
Nick
Corvette Z06 -1200ish rwhp
Old 11-06-2015, 09:16 AM   #7
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Like Unreal said you dont need another BOV that Vortech Maxflow is more than enough, if you can get the datalog, send it over to me and ill have Arun take a look at it.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 11-06-2015, 11:43 AM   #8
vortechc5@A2B Motorsport
Drives: 2015 1LE
I agree with Unreal. Not sure if SD would help since the BOV is so far way from the MAF.
vortechc5@A2B Motorsport is offline   Reply With Quote
Old 11-06-2015, 11:56 AM   #9
JANNETTYRACING
zl1 fuel pump
custom tune
You do need another bypass this will correct you problem seen it with these kits quite a few times.
The little 38 mm bypass is barely enough for 500 HP so I don't know who you talked to, but 1300 hp is not even in the ball park.
At 4500 RPM in a road coarse situation that blower is moving a lot of air and has no where to go with your throttle open slightly.
Air stacks up and rebounds like a Slinky in the cold pipe.
At 4500 RPM the blower is moving the same amount of air whether your throttle is open or closed, it needs a place to go.
At 1300 HP we run 2, 50 mm bypasses on the hot pipe for drag racing and would not be enough for road racing conditions.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 11-06-2015, 02:24 PM   #10
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Ted.
He's not running 1300 hp though.
Trob85 is offline   Reply With Quote
Old 11-07-2015, 12:13 AM   #11
1LeSS
1LeSS's Avatar
Appreciating the input. Myself, I'm stuck between the tune and the extra BOV.
I can't get a datalog because we've hit snow now. Should something change I will definitely grab a datalog .
I suppose you just want me to drive the car and capture when it is surging?
Thanks again
Ps, what is SD?
Old 11-07-2015, 08:43 AM   #12
Slowhawk
Drives: 1999 Trans Am
I would just dump the MAF, probably the route of the cause and go 2 or 3 bar SD.
Slowhawk is offline   Reply With Quote
Old 11-09-2015, 10:33 AM   #13
JANNETTYRACING
I didn't say he ways I was referencing what he was told by some one else that 1 38 mm bypass is good for 1300 HP which is laughable.
2 38 mm bypass valves will cure the problem no question about it.
This is not a new problem or a tune problem.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 11-16-2015, 09:56 AM   #14
1LeSS
1LeSS's Avatar
Thanks Ted. As soon as we get out of hibernation, I'll be giving you a call.
