Old 10-27-2015, 01:44 AM   #1
GTOWN
GTOWN's Avatar
Drives: Holden HSV Clubsport LS3
Cam spring advice
Just after some advice for the correct valve spring kit for a brian Tooley 227/234 614' 578 113+2 camshaft , the reason I ask is it has comp 918s at the moment rated to 625' lift and one spring broke over the weekend, the car had the cam done less than 8 month ago, and never driven hard.
Im alittle be wildered why its broken, is the 918 is the culprit??
GTOWN is offline   Reply With Quote
Old 10-27-2015, 01:59 AM   #2
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Not enough cushion for the springs limit would be my guess. You're not supposed to run a spring at or near the limit of its lift.
I would consider moving to BTR's .660 platinum double spring kit if I were you and never look back.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 10-27-2015, 08:49 AM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Having had trouble with a spring I would have to agree you should have had springs more in the .650 range and may have just gotten a bad spring or had a over rev weaken the spring. Your lucky if you have not had engine damage and the second spring saved it. You may just have gotten a bad spring.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 10-27-2015, 08:59 AM   #4
Bodywerks
Drives: 2015 2SS/RS/1LE
I fully recommend the btr660's as well, but not because of the lift rating. They are just a better spring.
Lots of other reasons the 918 could have broke. Springs weren't broken in properly, install height was wrong, bad spring out of the bunch, etc. Or the cam lobes are too aggressive even for only 614 lift. If a spring is rated for .625 lift then it is designed to handle that much lift when installed and used properly.
I chose the btr660 for my build, which has a 232/240 .654/629 pat g cam, and I fully expect the springs to perform well, because I installed them properly and will break them in properly.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 10-28-2015, 02:27 PM   #5
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
We use the BTR .660 Platinum Springs in our camshaft packages. We haven't had any issues to date.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 10-28-2015, 02:37 PM   #6
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
+1 on the BTR .660" springs.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 10-29-2015, 10:37 AM   #7
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
+9 on the btr .660's
Old 10-29-2015, 11:00 AM   #8
RankSS
You are very lucky there was not engine damage as the 918's are a single beehive.
I had the 918's as well but changed to the BTR .660's because I wanted the security of the dual spring and I heard lots of good things.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 10-29-2015, 12:55 PM   #9
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
Another vote for BTR .660. However you could just call Brian Tooley and see what he recommends for his cam...
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 10-29-2015, 01:21 PM   #10
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
+1 BTR .660 springs
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 11-04-2015, 09:02 AM   #11
GTOWN
GTOWN's Avatar
Ok guys thanks for the replies.....
The car is back on the road, the tuner put in BTR Dual kit, and im alittle bemused but reakons it had comp 650' lift single springs but on my invoice its says the part numbers for 918s and furthermore I have the comp box with my std springs which is for 918's, never the less, one spring snapped clean in half, no damage to the engine, so I got extremely lucky on this one, but im very happy the shop did the right thing and fixed the car and new springs for free....happy days are here again .
Old 11-07-2015, 04:23 PM   #12
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Thats nice that the shop stood behind their work
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 11-10-2015, 10:28 AM   #13
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I've seen way too many people talk about the BTR .660 springs. Don't have them personally yet, but when I get my build done, i'm using those
Current: 2015 ZL1, bone stock (gathering mods) | Past: 2010 2SS, full bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 11-13-2015, 11:45 AM   #14
Jason 98 TA
Drives: Camaro
Texas Speed has a .660 lift spring kit using pac doubles on special right now! You can also get a tsp camshaft with Callies camshaft core in 5150 or 8620 materials! As you can imagine a Callies core is top notch and so a cam failure is very unlikely!
Jason 98 TA is offline   Reply With Quote
