Old 10-27-2015, 03:24 AM   #1
Camaro724
Banned
Drives: 5thGen(2013)
What to do next? Want More HP+
I want more HP+ on my 2013 RS (V6) LFX engine.
I have:
K & N CAI
4" Borla Quad Cat-Back
I want more bolt ons if possible or anything to make it faster
Before going money crazy and buying turbos or super chargers!
Any ideas ?
Camaro724 is offline   Reply With Quote
Old 10-27-2015, 05:17 AM   #2
Awit92
Awit92's Avatar
Drives: 2015 camaro 2LS
SOLO High Flow Cats or ARH Downpipes
CAI Cold Air Intake, Vitesse Motorsports TC, Solo High Flow Cats, Muffler + resonator delete, Magnaflow Resonated X-pipe, Apex Air scoop, VMAX ported throttle body, Drake Shifter, Z28 spoiler + Zl1-addons Wickerbill, Eagle Eye U halo headlights. Items blacked out/tinted: Hood, wheels, emblems, brake lights.
Awit92 is offline   Reply With Quote
Old 10-27-2015, 09:18 AM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
JacFab intake and spacer and a good tune will make a big difference
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 10-27-2015, 12:44 PM   #4
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Tune, the GM tune is a joke even in "High Octane" tables. They can't even use what they learned from the LNF.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 10-27-2015, 03:15 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Solo high flow cats, intake scoop, ported throttle body, and a tune.
Old 10-27-2015, 03:22 PM   #6
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Listen to these two folks, they know what works. BTW it works for mine also. But you will never have enough HP. You get used to it and want more. Welcome to the world of Never Fast Enough.
etmx183 is offline   Reply With Quote
Old 10-27-2015, 03:29 PM   #7
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Buy a v8
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 10-27-2015, 04:07 PM   #8
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
ARH HFC, Ported Throttle Body and Underdrive Pulley + tune, you will pick up a little power but also notice a quicker throttle response due to the PTB and UDP.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 10-28-2015, 06:52 AM   #9
etmx183
etmx183's Avatar
LOL Buy a V8. so you can still mod it because it does not have enough power IE:ECS Novi 1500 supercharger, FSP cam, Tsp 2" longtubes, ZL1 fuel pump, Adm fpcm, Id850s, Aem meth, Mcleod rxt, ZL1 3.73 diff, BMR suspension, 17" weld rts, 4.5" M&H skinnies, 305 MT ET street R.
Like I said you will never have enough always want more. Enjoy what you have, mod it to make you happy. than mod it some more. 4/ 6/ 8 cyls does not matter, just get it, enjoy it, go fast safely and smile the whole time.
Old 10-31-2015, 09:24 PM   #10
MikosV6
Drives: '15 Camaro 1LS/M6
LGX ported intake by JacFab.
Ported TB with spacer
Relocated IAT sensor
Ditch the K&N
CAI intake/Rotofab with scoop
3.91 gears
Tune
Lower temp stat
HFC's
Vitesse TC
MikosV6 is offline   Reply With Quote
Old 10-31-2015, 11:17 PM   #11
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Again, the LGX intake WILL NOT with with the LFX engine. I am working on the LGX intake for the 2016+ cars. It will not fit 10-15 engines. I do offer a ported LFX intake manifold service for the 12-15 cars.
Jason@ is offline   Reply With Quote
Old 10-31-2015, 11:51 PM   #12
MikosV6
Okay thanks. I read the post you made about the LGX intake flowing about 10% better bone stock than the LFX intake. Makes me wonder what GM did to change it in such a way that it will not fit. I wonder if with some "modifications", if it would work on the LFX?
Old 11-01-2015, 11:49 AM   #13
camrytt
camrytt's Avatar
Drives: 2014 L99
I'll save you a lot of time and money. Don't bother with all that. If you want horsepower just get the turbo. None of that other stuff will make a difference.
Current: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears.
Past: '12 LFX, full bolt ons + E85, 302hp/267tq
camrytt is offline   Reply With Quote
Old 11-02-2015, 11:23 AM   #14
Jason@
The new LGX is quite a bit different than the LFX it replaced. While not impossible to get the LGX intake on an LFX, it would probably be a very expensive task.
On average when I finish modifying an LFX intake, it flows about 20% better than stock. With that, I don't see a reason to pursue trying to make an LGX intake fit the LFX engine.
