04-28-2024, 09:33 AM | #1 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
LT4 Supercharger bleeder tool!
I was having higher than expected temps on my IAT 3 and Ted at JRE recommended this tool. It's probably the best $89 I've spend on a tool!
It fits on a water bottle or a 2 liter bottle. To attach to the fill port/bleeder valve. Just pull the gold housing upward, then put the fitting on the fill port. It slips and snaps on the bleeder/fill port and locks in place when you let go and it's liquid tight. When your done, pull the housing back upward and pull the bottle off. All the excess liquid stays in the bottle and NO MESS! It was a breeze bleeding out the reaming air in my SC coolant system!
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper 15% / 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | E85 | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | Mighty Mouse 1000 | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned
04-28-2024, 09:55 AM | #2 |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
Or You can get one of these and never worry about it
https://lsa-conversion-store.myshopi...sivoir-upgrade |
04-28-2024, 12:46 PM | #3 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Thats a great option for those who do not have or want an expansion tank! As I dont see any on the market that fit away from the headers :( I am trying to fit in a Magnuson tank now, but they just dont fit anywhere good :(
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
04-28-2024, 01:54 PM | #4 |
The Magnuson is a nice tank! I do have the DMS Fender Tank. But, it is so much easier to bleed and top off at the SC fitting than the fender tank. If I'm not careful, I've overfilled the fender tank and only noticed once I saw coolant on the floor!
04-28-2024, 01:55 PM | #5 | |
04-28-2024, 03:11 PM | #6 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I have a Cordes expansion tank and it's not mounted by the headers. It's right behind the radiator in front of the belts.
04-28-2024, 03:43 PM | #7 | |
I ran my lowest line along the wheel well where the brake lines are They are nowhere near my exhaust |
04-28-2024, 04:19 PM | #8 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
04-28-2024, 05:01 PM | #9 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
04-28-2024, 05:08 PM | #10 | |
Photo?
04-28-2024, 05:50 PM | #11 |
The only problem with these pop bottle adaptors, is you cannot control the purge valve. I cut the centre out of mine, so I can use a
Poker to purge when I want. And also withdraw the leftover antifreeze from bottle, before I disconnect from the system without introducing air. |
04-28-2024, 06:14 PM | #12 |
Mine went under my Air cleaner also
04-28-2024, 06:38 PM | #13 |
I am trying to shoehorn the maggie expansion tank here... between the rad / fuse block, but a friend mentioned it was too low in the system... thoughts?
Sorry for the HIJACK :(
04-28-2024, 07:00 PM | #14 | |
Get rid of the window washer tank and use that space..\ I heard most take off their wipers anyways |
