09-20-2014, 03:09 PM | #1 |
Drives: 2010 camaro ss Join Date: Apr 2010
Rims corroding..
Has any else had this issue? All four of my rims seem to be corroding, some worse than others? The car is a 2010 ss, has anyone else had this happen to their rims and if so what did you do about it? Or is it chevy/ the dealerships issue? Thanks
09-20-2014, 03:12 PM | #2 |
Meshamey
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1 Join Date: Apr 2013
wow...Have you used any type of cleaner that has eaten of the protective coating?
09-20-2014, 03:15 PM | #3 |
09-20-2014, 03:21 PM | #4 |
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Oct 2013
wing NJ I bet it's fromroad salt, you may have had bad clear coat on the rims and the salt from the wet roads is causing corrosion. Won't be cheap to fix.
Hurst Short Throw Shifter, K&N CAI, SRP Racing Pedals, GM Performance Exhaust, GM GFX Package
Lakewood Strut Tower Brace, JBA Shorty Headers, JBA 8 MM Wires, Airaid TB Spacer, Phastek CAI Scoop, Washer Bottle Relocation Kit, Stainlees Steel Brake Lines, Brake Performance Slotted and Drilled Rotors, BMR Tunnel Brace, BMR Trailing Arms, BMR Subframe Connectors, Borla ATAK Muffelers, Z28 Wickerbill Spoiler, VTC, Bow Tie Delete, BMR Adjustable Front Swaybar, BMR End Link Kit, BMR Extreme Rear Anti-Roll Kit, Diablo I1000 "InTune" |
09-20-2014, 03:41 PM | #5 |
Didn't think about salt being the issue cause it it only really happened and got bad recently (past couple months). Could this issue be under warranty of some type, the rims shouldn't be corroding like that...?
09-20-2014, 04:15 PM | #6 |
3 year- 36,000 mile warranty is all you get.
09-20-2014, 04:21 PM | #7 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
You must clean your wheels at least once a week especially with NJ winters. My '10 SS
polished wheels are still fine after 5 years. It's obvious you didn't keep up with them. Also, I doubt that damage just showed up in the "last couple of months". That's salt getting under the clear coat. Just my opinion.
09-20-2014, 06:03 PM | #8 | |
the car doesnt get driven that much in winter but no i dont clean them as much as i should.. it was never this bad till i really looked at them and washed the car today. guess it will be cheaper to get some rims next summer and keep these for winter |
09-20-2014, 06:04 PM | #9 |
anyway or products i could use to get this out also?
09-20-2014, 06:12 PM | #10 |
Drives: 2014 Camaro SS/RS Crystal Red Tintc Join Date: Aug 2013
There are places that do re-finish them. Maybe someone on here is more familiar with what kind of results and cost that would be.
2014 Camaro SS/RS Crystal Red Tintcoat |
09-21-2014, 02:45 AM | #11 |
Adam E. Lucchesi
I've only seen this once. I work on a car lot, and we recently got in a 2LT/RS that has that same issue. Looks just like yours, but not quite as much of it.
09-21-2014, 09:34 AM | #12 |
Oldbie that nobody knows
It's called Filiform or "underfilm" corrosion, thus why it spreads in that unique way. Salt, dirt, or moisture manages to break though the clearcoat and causes corrosion to spread under the clearcoat.
Only fix is to strip off the factory clear, sand away all traces of corrosion and refinish; or, if desired, maintain as bare aluminum. |
09-21-2014, 11:54 AM | #13 |
Yep. Been trying to get mine fixed under warranty since May. No dealerships want to mess with it, and my CSR is useless.
Who owns this car with the Peace Sign, Mag Wheels, and 6 on the floor?
09-21-2014, 11:55 AM | #14 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
I see some curb rash in one pic, that always helps get it started. And neglect.
Brake dust eats your wheels up.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
