Old 08-16-2014, 02:43 AM   #1
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Do these numbers make sense?
I won't say the shop name but my car made 505 rwhp with the turbonetics turbo kit. Here is what it has done
A l99 to ls3 conversion with a cam (115+ so works with forced induction)
3200 yank stall
full custom exhaust
85 lb injectors
ADM FPCM
zl1 fuel pump
102 Fast Intake Manifold
Several Upgraded components on turbo kit. I don't know what psi they set it at, I pick up tomorrow but I assume 8 psi.
Does that sound good or kind of low to you?
DaFisch is offline   Reply With Quote
Old 08-16-2014, 11:22 AM   #2
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
your stall will hold some hp back but not familiar with your kit , seems low, but I have a L99 to ls3 conversion, Maggie with 8lbs boost , cam/headers/cai... with 22's on the back,,, and made 586 rwhp.
bmbbl be is offline   Reply With Quote
Old 08-16-2014, 11:49 AM   #3
caper
Drives: 2010 IOM 2ss/RS
if you still have your cats that's holding back power too. im not sure how much the auto drives down your hp #. mine was measured on a mustang dyno.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 08-17-2014, 02:59 PM   #4
DaFisch
DaFisch's Avatar
I am not running any cats
Old 08-17-2014, 03:04 PM   #5
sprayedv
Drives: 2012 CTS-V, 2010 Camaro SS
Single or twins? Turbo size? Boost?
Lots of factors can influence your power level. Maybe they have it on a very safe tune.
My camaro has pretty much same mods as you except stall and I'm running a maggie ... at 7-8psi i was around 580~whp.
2012 CTS-V: Cosmetic Chute.
sprayedv is offline   Reply With Quote
Old 08-17-2014, 04:06 PM   #6
Unreal
Drives: 2006 Z06
Turbonetics is a single up top with U turn headers.
Seems way low but hard to say. I know all the AGP kits at 10-11psi are doing ~650rwhp on l99 autos with no other mods. No cam, no ls3 conversion, nothing but turbos and the fuel system to support that boost.
Nick
Corvette Z06 -1200ish rwhp
Old 08-17-2014, 09:00 PM   #7
DaFisch
DaFisch's Avatar
Yeah I was hoping for over 600 they did say the tune conservatively. I am going to add heads at another shop and have them retune then
Old 08-17-2014, 10:40 PM   #8
TheMeat
TheMeat's Avatar
Drives: 1973 Camaro
Without more info, we're just guessing why your car produced those dyno numbers.
'Conservatively' is a bit subjective.
73 Camaro, 6.0 LS, Billet S485, E85, 4L80E.
TheMeat is offline   Reply With Quote
Old 08-17-2014, 11:29 PM   #9
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Once again...get a base dyno and look at the gain...that's what you are after.
-John S.
Old 08-18-2014, 09:36 AM   #10
CamaroSS sleeper
Drives: Sleeper_NOT
Something is not right.
thats what the kit makes stock with the can tune @ 5.5-6 psi
CamaroSS sleeper is offline   Reply With Quote
Old 08-18-2014, 10:41 AM   #11
east TX Muscle cars
east TX Muscle cars's Avatar
Drives: 2x 05 Vettes/65'AC cobra/68 camaro
sounds like your on a VERY low PSI.
just about any kit we install with 8-9 PSI and ls3 conversion will do in the 640-680 RWHP range with a stall also. 91 OCT fuel will knock out about 20-30 RWHP if your a 91oct state.
the cam has alot to do with the HP gains also. our stg 2 FI cam nets usually 80RWHP with just the cam on a FI car.
We need more info.
PSI
CAM specs
kind of dyno
still its just a number no matter what. take it out to the track see what she traps that will tell you true HP
east TX Muscle cars is offline   Reply With Quote
Old 08-18-2014, 10:49 AM   #12
NicKey_Tuner
Drives: Z28
Sounds a bit low, is it the single disc or triple disc yank. If it wasn't locked up at WOT that will affect the HP numbers on the dyno some.
NicKey_Tuner is offline   Reply With Quote
Old 08-18-2014, 11:19 AM   #13
DaFisch
DaFisch's Avatar
Base dyne was a 455 with following mods
3200 yank stall
ported throttle body
ls3 conversion done by Speed Inc
Custom Ground Comp cam by Speed Inc
What was added
102 intake manifold
zl1 fuel pump
adm fpcm
85 lb injectors
Old 08-18-2014, 11:23 AM   #14
CamaroSS sleeper
Drives: Sleeper_NOT
you can also check the springs in your wastegates, make sure you are using the correct ones.
Blue Stripes = 5psi
white stripes= 7psi
Red Stripes = 9 psi
with no additional preload from the set screw.
