03-26-2010, 08:08 PM | #1 |
Drives: 2010 Camaro 2LT RS, 2009 GTR Join Date: May 2009
Oil Pressure Gauge for the V6
About 300 miles ago I had my oil switched to Mobil 1 and everything was like normal. But today on start up my Oil Pressure gauge went straight to 70 PSI and only went down when I came to a complete stop. I would mildly accelerate and it would keep climbing up to 70 PSI again. I checked the oil just in case to make sure it was alright and it was fine. I Onstared it and they said that they could not find anything wrong and told me to take it to a dealer to get a better idea of what was happening. She's never done this in all 4300 miles that I've had her. I'll check to see if she does it again tomorrow but I just wanted to here any possiblities. I am hoping the gauge was just having issues and it doesn't do it again.
03-27-2010, 08:14 AM | #2 |
Drives: 2010 Camaro 2LT RS SIM Join Date: Feb 2010
Hope nothing is wrong. What is the normal operating PSI? Also whats the normal operating temp for the oil and transmission fluid?
The "ENTICER" |
03-27-2010, 09:13 AM | #3 |
Drives: 1969 Chevelle, 2010 1LT Join Date: Jun 2009
Was the right viscosity used? If not, it could affect the oil pressure.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation 2000: 8/15/09 - Accepted by GM. 2500: 8/18/09 - Preferenced. 3000: 8/18/09 - Accepted by Production Control. 3100: 9/9/09 - Available to Sequence. 3300: 9/9/09 - Scheduled for Production. 3400: 9/19/09 - Broadcast. 3800: 9/29/09 - Produced. 4000: 9/29/09 - Available to Ship. 4150: 9/29/09 - Original Invoice. 4200: 10/6/09 - Shipped. 5000: 10/13/09 - Delivered to Dealer. 6000: 10/13/09 - Delivered to Customer. |
03-27-2010, 09:17 AM | #4 | |
Drives: 2010 F150 Lariat, Candy Red Join Date: Aug 2009
I would recommend you do it yourself. Check oil pressure again. |
03-28-2010, 08:32 PM | #5 |
Everything was a straight change. I had my dealership do it. New filter and a brand new box of Mobil 1. Everything was great until the other day. It did the same thing today upon start up.
I emailed the dealership closest to me as I am about 2 hours away from my normal dealer (as I'm in college). |
03-31-2010, 03:51 PM | #6 |
I know for a fact that each morning when I start my car up cold, the oil pressure goes to 70psi and will basically stay there for a few minutes until the engine attains operating temperature, whether at idle or not. Then the idle pressure will drop down to normal, around 30psi. I think what you might be experiencing is normal. If your still in doubt, then take it in.
04-01-2010, 02:58 PM | #7 |
I know that it goes to 70 and then drops to around 40 but mine stayed at 70 for extended periods of time.
I took her in today and an hour later I got a call saying that they fixed it. Somehow a piece of the guage was loose so it was reading as it was running hot/high when it was cool/low. So there was nothing truly wrong besides a loose piece. |
04-01-2010, 03:12 PM | #8 | |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
04-05-2010, 12:11 PM | #9 |
Drives: 2010 Camaro 2LT/RS Join Date: Aug 2009
Same thing here. The V6's run very high oil pressure, especially at startup. I wouldn't worry about it.
Similar Threads | ||||
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
V6 Oil Filter Housing - Fill w/ oil when changing oil? | bono83 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 15 | 12-06-2009 08:46 PM |
Oil pressure drops bad | wetodd | 4th Generation Camaros | 26 | 11-25-2009 07:38 AM |
Need help..No Oil Pressure !!! | BabyBee2010 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 10-22-2009 06:25 AM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
