01-06-2018, 04:13 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Sloppy Brakes... What is the Cause?
I have tried just about everything.. But for some reason my peddle still feels soft and inconsistent.. Im starting to consider all potentials.. I have stainless lines.. I have bleed the system on more then one occasion with no air bubbles..
Could it potentially be caused by my Stage 3 PD BTR cam? Maybe i need to activate the ABS system when bleeding? Potentially add an aftermarket brake booster system? What are your recommendations.. |
01-06-2018, 10:56 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I installed a big in a motor years ago and lost a lot vacuum you may need a vacuum reservoir?
Orange Krush II
01-06-2018, 11:03 PM | #3 | |
Drives: 2015 Camaro 1SS 6M Join Date: Dec 2017
I love ATE brake fluid. It's the only one I haven't boiled, and I used to make my rotors glow on the 240Z. Stay safe and be cautious, any inconsistancy with braking can be scary. |
01-06-2018, 11:06 PM | #4 |
Also, try Porterfield R4s Pads if you beat your car AND need the brakes to work below freezing temps. They were amazing from my experience. I have noticed the Hawks seem to bite harder as they warm up, where as the R4s bites much harder initially and has a more progressive gain, never fading.
Are you having issues while driving normally or on track? Pads will change their friction charactaristics as they change temp, also regular dot4 fluid boils easily and could be another issue. |
01-07-2018, 12:27 PM | #5 |
01-07-2018, 12:29 PM | #6 | |
01-07-2018, 08:56 PM | #7 |
Drives: 62 Chevy & 2021 1SS/1LE manual Join Date: Aug 2010
ive had the exact thing happen after caliper rebuild. you definitely need to keep bleeding. do this bother...
bleed em 15 seconds per bleeder, inner and outer, starting at the right rear, then left rear, then left front, then right front. as soon as you do this, take the car out somewhere safe and purposely active the abs by over braking. do it til you feel the springy fuzzy feel when the abs kicks in. i normally do this 3 or 4 times. then immediately go back and bleed again 15 seconds per bleeder inner and outer in the same order. |
01-09-2018, 05:43 PM | #9 | |
Activating the abs may also be a good idea, although I have not had to do that to bleed brakes. High volume of flow usually gets the bubbles out, if not, pumping the pedal can disperse/foam the bubbles and help to get the air out. A word about powder coating brake calipers.... Have you seen the chemicals they use to strip the paint? I have a free connection on powder coating and I'd never have my calipers powder coated. The paint stripper can etch the aluminum, although this does not commonly cause problems it still makes me uncomfortable. Are your calipers leaking by any chance? |
