01-05-2017, 03:48 PM | #1 |
Pull power from where??
I klnow i have another thread about this but i would love to get this done within the next few minutes and get everything all buttoned up. I am hardwireing my radar detector. All wires are run just need power, i went with the add-a-circuit for getting power. Which fuse port do i use? I dont want it to come on when i start the car only when i turn the detector on. Thanks in advance.
01-05-2017, 09:56 PM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
From my exploring the only switched fuses are for the power outlets, F17/18. The rest are always hot.
2011 1SS/RS LS3 CGM
01-06-2017, 05:18 AM | #3 |
Thank you very much
01-06-2017, 06:34 AM | #4 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I got mine from F17 using a fuse tap like this. Gnd wire went under a screw.
01-06-2017, 06:56 AM | #5 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I have a Valentine 1, and did it just like this
http://www.camaro5.com/forums/showth...ighlight=radar |
01-06-2017, 07:29 AM | #6 | |
01-06-2017, 08:33 AM | #7 |
Drives: 2013 2SS/RS Join Date: Nov 2015
Have in on hot and add a switch. That way you can control it that way? But if it has an on/off button on the unit, it shouldn't matter if it's on hot or not. The power button would be what turns it on and off.
01-06-2017, 10:13 AM | #8 |
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox Join Date: Apr 2013
01-06-2017, 12:26 PM | #9 |
I have the same set up as ZED SLED, should i run 5 AMP or 10 fuse? Love that mirror attachment, just ordered mine.
Thanks for all the info gentlemen.
01-06-2017, 12:37 PM | #10 |
I have a 5 in mine but 2 would probably protect better. I have a 9500ix and I think it draws about a half amp.
01-06-2017, 12:44 PM | #11 |
Ok great ZED SLED, how was the fitment using F17?
01-10-2017, 12:13 PM | #12 |
I think it was 17 but may be 18. Whichever one the double size fuse tap fits in. I think it there's space in one but not the other. Can't look to see because the car is garaged under cover with a bunch of snow removal stuff surrounding it til April.
