08-11-2014, 04:36 PM | #1 |
"Cam Only"
Help with simple sub setup
Hey, I've been looking and looking through these threads and searching about doing a subwoofer install and it still isn't very clear to me how to do this.
I have the BA system in my 2013 2SS/RS. If I just want to replace withe factory amp with something a little better, and have one or two subs in the trunk for some extra bass, what would you guys recommend? I don't need a crazy ridiculous system, and I want to keep the cost fairly low, but I am okay with spending a little more for a JL audio setup. Don't want to spend more than around $600ish for the parts. if that's reasonable...? I will build my own enclosure for the speakers because I want to be able to quickly take the enclosure in and out before races. So what do I need? Amp Sub(s) Wiring harness? If you guys could help me out with some links, that would be greatly appreciated.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
08-11-2014, 05:42 PM | #2 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
You can use this harness to not splice any of your factory wiring and then you can swap out the amp with the amp of your choice.
http://********.com/product_info.php...roducts_id=338 |
08-12-2014, 07:52 AM | #3 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
Non BA system.
Jeff_SS I finally found all of my pictures again and will just post them up here later after work. It will make it more clear. I used the PAC SOEM-T line out converter. The amp, subs, and box all depend on how many subs you want to run and how much space you want to take up in the trunk. Here are the 2 setups I have had for sub/amp combos:
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts Last edited by BenningJ; 08-12-2014 at 07:53 AM. Reason: Subscribed for quick notification of activity |
08-12-2014, 10:52 PM | #4 |
"Cam Only"
Thanks BenningJ,
Looking forward to more details.
08-13-2014, 05:10 PM | #5 |
Here are the pictures to show the install. I hope they are clear.
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
08-13-2014, 11:01 PM | #6 |
"Cam Only"
Thank you BenningJ, this will help me a lot when I go to do this upgrade!
08-14-2014, 08:07 AM | #7 |
You're welcome. Sorry it took me so long.
