05-11-2015, 02:30 PM | #1 |
Drives: White 2016 Z06 Join Date: Aug 2014
Lambo door help.
Anyone ever see Lambo doors that can open normal or up for the camaro
Hmmm now where did I put that screw
05-11-2015, 02:43 PM | #2 |
05-11-2015, 02:48 PM | #3 |
Drives: 2014 2LT/RS Join Date: Nov 2012
well that was easy ^^ haha
05-11-2015, 02:55 PM | #4 |
[/URL]
[/URL] |
05-11-2015, 02:55 PM | #5 | |
Drives: 2013 Silver Ice Metallic Join Date: Aug 2013
Vertical Doors Inc. or VDI has a set that open 2 feet, plenty of room to get in and out - but they also open up. Here are mine...
05-11-2015, 03:06 PM | #6 |
Drives: 2015 ZL1 Join Date: Mar 2015
How well do they work? What are the issues with them? For those of you who installed them, is there anything about them you regret, or anything you miss about the OEM doors?
Edit - Libertypilot's video was great, thanks. |
05-11-2015, 03:36 PM | #7 |
Drives: 2011 camaro 2ss/rs rally yellow L99 Join Date: Nov 2011
Sorry had too
- Airaid cold air intake - Kooks 1 7/8 long tube headers
- Kooks high flow cats - Borla atak 2.5" cat back exhaust - Dyno tune - AFM delete - 94 octane tune - Vitesse paddle shifters - Blacked out rims - Costum painted engine cover - T3 stripes - GM locking gas cap |
05-11-2015, 04:07 PM | #8 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
^ The most overplayed pic on this site.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-11-2015, 04:15 PM | #9 |
Drives: 2020 rally green rs Join Date: Oct 2013
but great!
05-11-2015, 06:04 PM | #10 |
Those doors are soooooo ugly.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-11-2015, 06:11 PM | #11 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
05-11-2015, 06:18 PM | #12 |
Drives: 2015 2SS L99 Join Date: Jun 2013
The VDI doors are the best. As stated earlier, they open normally or up. Use them when you want. No regrets at all!
Factory Reproduction ZL1 Rims / Volant CAI / Vitesse Throttle Controller / Corsa Cat-Back Exhaust
05-11-2015, 06:37 PM | #13 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
05-11-2015, 07:03 PM | #14 |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
All that is missing is the obnoxious paint job and 32" wheels
