01-20-2016, 10:36 PM | #1 |
DAP-ONE [COTW - 12/23/13]
DIC Message - Trunk Open
I started having a weird symptom over the weekend. When I turn on the vehicle I get a "Trunk Open" message on the DIC, even though the trunk is actually closed. Then, when I open the trunk, the "Trunk Open" message goes away. Has anyone run into this before and what did you have to do to fix this? I've tried replacing the fuses in F23 of the driver-side fuse panel, but still getting the same symptom.
01-21-2016, 12:35 AM | #2 |
Drives: 2014 2SS/RS Join Date: Jun 2013
Electrical issues are such headaches
Could be a ground. If the fuse is together, its good no doubt. Maybe theres a sensor? I dont want to give you wrong information |
01-21-2016, 10:37 AM | #3 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
Check the switch in the trunk and the wiring to make sure the connector hasn't come off.
USMC 1980-1990
My other toys are Harleys |
01-21-2016, 06:04 PM | #4 | |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
Agree. I would suspect an open circuit giving a false positive, the connector might just be loose.
01-24-2016, 12:31 PM | #5 |
Thanks, guys! I will check that out. I have a trunk lid cover with the LED lighting, so it is very possible that the connector has come off.
01-24-2016, 11:28 PM | #6 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
This happens to me from time to time. Haven't done anything about it. If it was a loose switch or connection I think it would do it a lot more. Maybe it happens only when an angel gets its wings.
Meh
01-25-2016, 12:46 PM | #7 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
You may have a trunk monkey.
01-25-2016, 10:21 PM | #8 |
I wondered what that awful smell coming from the trunk was. Also explains why none of the bananas I buy at the store make it home.
Meh
05-27-2016, 06:24 PM | #9 |
Forgot to close this out, but my issue turned out to be the trunk lid latch. Dealer ordered the part and replaced the bad one for me.
