12-01-2011, 08:44 AM | #1 |
HARD WORKING PATRIOT
Drives: 2011 CAMARO 2SS RS-AUTO Join Date: Oct 2010
12-01-2011, 10:10 AM | #2 |
I want to know how you convinced the dealer it was a porosity issue?
12-01-2011, 10:56 AM | #3 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
Glad to hear you followed the dye-in-oil advise and they were able to pin point the source of the oil leak right away. The rear engine cover porosity issue is actually not uncommon and is a documented problem on the alum engines. Don't be concerned with the RTV..it should last as long as the engine. Believe it or not, to this day, a lot of old school mechanics still prefer to use RTV over a gasket. When I built my FFR (blue car in sig), my thermo housing mating surface to the engine wouldn't stop seeping....finally fixed it with RTV.
Anyway, since the dealer changed your oil after the job on the rear engine cover, we can't blame contaminated oil. My suspicion is you have the early sign of the L99 lifter problem. It will only get worse and you will start to see a cloud coming out of your tail pipes, especially on high accelaration. The tick tick tick sound will get louder over time. This problem is well documented for the L99 so you shouldn't have an issue getting it fixed under warranty. Not to discourage you but I suspect your oil leak issue is not completely fixed. It is awesome that they found the rear engine cover porosity prob right away but the oil cooler leak and/or oil pan leak take a few days to drop oil on the floor so keep an eye out for it. Good luck. |
12-01-2011, 11:52 AM | #4 | |
1. Any worry of remaining contaminants is put to rest 2. Any worry the dealer might have put the incorrect oil is put to rest 3. Any worry of RTV clogged up oil filter is put to rest now after this is done and the lifter noise is still prevalent then time to visit the dealer for the L99 lifter problem under warranty (it is not unusual for engine to tick at first cold start up and even some after warm start up but it should go away after a short drive) |
12-01-2011, 12:36 PM | #5 |
FWIW, my car sits for weeks at a time between starts and I always get a ticking sound on the passenger side of the engine (apparently so do some members here) after 1 minute or so of cold start up....the ticking doesn't go away with car just idling...but when I take the car for a short drive (a block) and park and listen, the tick always goes away. last time I was at my dealer, a salesman friend let me start up a new SS in the lot (manual like mine), and after a minute, the ticking noise occured but also went away after a short drive.
Also, keep in mind, engine ticking tends to occur more in cold, especially freezing weather...it is takes longer for oil to do its job in the engine when the weather is very cold or freezing. This is why some swap thick to thinner oil during season changes. |
12-02-2011, 08:29 AM | #6 |
Tim:
A louder exhaust cures the lifter noise... This is probably why I worry about that supercharger on my L99...when go boom? The lifters are weak (SAD) and I know I will need to address this down the road. The nice thing is that I do have an Edelbrock warranty that will buy me new parts if broken...LS3 conversion time when that happens.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
Similar Threads | ||||
A Look at GM's Oil Life Monitoring System | franknbeans | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 166 | 05-23-2014 06:31 PM |
How to see if oil is in intake manifold? | CamaroC-17 | 5th Gen Camaro SS LS LT General Discussions | 53 | 03-23-2011 05:06 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
