Old 09-12-2018, 05:03 PM   #1
San2cci
San2cci's Avatar
Drives: 2013 silver ice metallic ZL1
Help with pulley & tune suggestion
I'm curious about getting this 10% overdrive pulley I keep reading about for more boost? Can someone give me some info about it and on what I need purchase to do this?
Also anyone know any good tuners in the philadelphia/south Jersey area? After I change the pulley I will be needing a tune.
Not new to camaro's, just new ZL1 specific mods. Thanks for your help
San2cci is offline   Reply With Quote
Old 09-12-2018, 09:15 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
10% lower, CAI, tune, 75 rwnp. I had great success with JRE. If you buy a ATI or Lingenfleter balancer I have my original 10% ring and maybe a new belt, I would have to check the garage attic. Hit the JRE site or just search there are years of success on the forum.
ZMEnow is offline   Reply With Quote
Old 09-13-2018, 09:01 AM   #3
San2cci
San2cci's Avatar
I have a CAI and kooks headers with high flow cats...I'm not looking to generate a ton of extra power just a little more. I figure the pulley would help and then getting a tune on top of it.
Old 09-13-2018, 09:28 AM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
You will need a tune after adding a pulley. A lower 10% overdrive is a solid upgrade and won't push your set up to hard. Give us a call and we can go over some options. We have ATI and IW systems in stock.
Juiced1 is offline   Reply With Quote
Old 09-13-2018, 10:13 AM   #5
BossRS4
BossRS4's Avatar
Drives: 2013 Camaro ZL1
Do you need new fuel injectors with a 10% pulley?
2013 Yellow Camaro ZL1
Purchased: (9/24/16)
5% Tint All Around
45% Tint on Windshield
Roto-Fab Cold Air Intake
Oracle Afterburner Tail Lights
Oracle LED Sidemarkers
RDP Tune
TSP Long Tube Headers
Forza Componenti 3-Way Exhaust Controller
ZL1 Addons Wicker Bill
BossRS4 is offline   Reply With Quote
Old 09-13-2018, 03:43 PM   #6
ZMEnow
Being honest I regretted adding headers to my 10% lower 75RWHP after running it a whole year without headers. Sounded great, but it just didn't have that snap, and that was because of the improved flow which is slightly lower boost. Yes the headers were mandatory for the next step so I did move on with 18% ID850's, plugs and BAP, and that brought the snap back but plenty of Heat Soak.
Old 09-15-2018, 08:58 PM   #7
BURNYs
BURN RUBBER NOT YOUR SOUL
BURNYs's Avatar
Drives: 2013 ZL1 M6 Blue Ray
Go to Complete Street Performance in West Chester. They do great work.
Mods-Kong Ported Blower, ID1700X injectors, 2.35/8.65, TSP Ported Heads, Custom Grind Cam, RPM 5 inch Intake, NW 102mm, Kooks 1 7/8, Corsa Extreme, Afco Heat Exchanger, PNR 4 gal ice tank/EMP pump, Oil catch can, Thermal reduction plates, BR7EF plugs, DSX Aux Pump, Monster LT1-S triple. 788hp/757tq-93, 839hp/785tq-E85. Burn Rubber Not Your Soul
BURNYs is offline   Reply With Quote
Old 09-15-2018, 10:50 PM   #8
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Mandatory for what step, the headers?
silversleeper is offline   Reply With Quote
Old 09-15-2018, 11:04 PM   #9
ZMEnow
Above the 10% lower you need the headers to improve the flow/backpressure for the extra boost.
Old 09-17-2018, 07:36 AM   #10
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Race Proven Motorsports isn't far from you - New Castle Delaware. They do a whole lot of LS and LT stuff with great results.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 09-17-2018, 08:58 AM   #11
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
And they have a really good YouTube channel, too. Gives you a good feel for the shop and how they work.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 09-17-2018, 09:58 AM   #12
acammer
acammer's Avatar
I'm a subscriber - I like getting in on the dyno guesses. I can usually hit within a few percent.
Old 09-17-2018, 05:23 PM   #13
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Lowering the boost number doesn't change how much power it makes, the blower is still moving the same CFM in, it's just under less pressure. Put a ZL1 on the dyno with 10% pulley with and without headers, if both are tuned properly, the Header car will make more power across the board, possibly lose a negligible 10 RWTQ or so at 0-2500 - MAYBE. More than likely, more torque and power across the graph. Lower boost number doesn't mean lost power or torque. Just less pressure.
Can'tHave2MuchHP is offline   Reply With Quote
Old 09-17-2018, 09:12 PM   #14
ZMEnow
Just sharing my personal experience, and yes I didn’t waist a lot of time with AFR before going with the 18% injectors and BAP.
