Old 07-11-2013, 08:45 PM   #1
429
Drives: 2010 camaro ss
Changes
In the never ending effort to go faster with a limited setup and budget, I ended up with a holley hi-ram intake. While this increased trap mph 3.5mph and horsepower by a good bit, the car lost low end, and couldnt get off the line hard as it needed to (1.48 60 foot went to 1.65 60 foot, dead hook). Problem was the circle-D 5C stall wasnt stalling high enough to put the engine in the powerband.
Yeah, we fixed that. After having a transmission issue necessitating a minor rebuild, I had Chris @ Circle-D change the converter from a 5C to a 3E race stator. Hopefully the car will stall to 52-5400 now, and gain efficiency on the big end as well. Really think this is the last piece of the puzzle to finally running my 9.99 n/a in this damn car. Hopefully we will get some good weather this fall, and I can make an honest effort to run the number
http://s304.photobucket.com/user/Gho...?sort=3&page=1
429 is offline   Reply With Quote
Old 07-11-2013, 08:47 PM   #2
Supercharged SS
Drives: 2010 Camaro
Best of luck kid!! If anyone can do it its you!!
Old 07-12-2013, 09:47 AM   #3
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Thanks for the update, you'll get there, what was the MPH and the DA?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-12-2013, 10:17 AM   #4
429
Car went 6.6 @ 99.6 mph 1.48 60' in 500DA with fast 102 setup
Car went 6.6 @ 103.5 mph 1.65 60' in 3300DA with hi-ram setup
Obviously, it picked up, especially given the worse weather. Just had no guts off the line since it didnt make as much tq or power at the stall speed vs the fast. Stall change should gloriously fix that and make it more efficient up top too. Hoping it goes 6.4@104-105 and 9.9@~133-135 in the quarter this fall, with some better weather... then I can finally spray it to the moon and shoot for 8s
Old 07-12-2013, 12:29 PM   #5
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Very interesting! Can't wait to see the results of the converter changes!
Camarojt is offline   Reply With Quote
Old 07-12-2013, 02:25 PM   #6
Pro Stock John
Writer
Nice big gain at the 1/8th even with the crummy DA.
Good luck with the restall, 9's on motor is a grail of mine though I'll end up doing it in a lighter car like a notch.
PROJECT HEAVY CHEVY
Old 07-13-2013, 02:31 PM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
You'll like the e converter!
Rhino79 is offline   Reply With Quote
Old 07-13-2013, 08:05 PM   #8
429
Converter + Trans should be done and installed this week by Thursday, if my trans man gets it done on time. Finishing up last tidbits... oil change and flushing of the trans cooler... airing out to dry now.
Old 07-14-2013, 09:38 AM   #9
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
after i get some other things done on my old cars , i thinking about tryin this intake on a factory size ci motor and see what the gains are. even if it dont gain anything it looks badass lol
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-15-2013, 10:58 PM   #10
429
Gonna need to spin it to 8000 to make power on a 6.2, just saying.
Old 07-16-2013, 10:40 AM   #11
Pro Stock John
Writer
... Or maybe run a cam that won't fit (PtoV) in our cars... that's what I'm thinking.
PROJECT HEAVY CHEVY
Old 07-16-2013, 04:27 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i dont think u will have to spin that hi to get gains . but if u want the most out of it u will. 7200 sounds about right for starters
my cam is close on ptv with stock heads. .647 intake 235 dur. and 111 sep.
Old 07-16-2013, 08:57 PM   #13
Rhino79
Rhino79's Avatar
And that's the lsk lobe, very aggressive. It will love the rpm if the valvetrain is up to it!
Old 07-16-2013, 09:20 PM   #14
429
The intake pushed my power peak up 900rpm, and I have 430 inches and a whole lot of compression.
