Old 07-20-2013, 06:54 PM   #1
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Whipple belt shredding issues pics/vid
Hey all, I seem to be having issues with my belt liking to shred. In the first 200kms of whipple install I shredded one. I wrote that one off to something else. Well I put another on and I went on a 500km trip south, and saw a pile of rubber built up again. Did 5 passes down the track and no more rubber, thought maybe its just breaking in. Drove home and in total about 2000kms and now it's shredding rubber again. And I'm getting a strange noise at start up from the belt. It's almost off the edge of the tensioner, which I think is my issue. It's wrapped tight around the sc pulley. Not sure if the lower idler pulley is recessed in too much causing it to be misaligned on the tensioner. On to the pics and vids.
http://youtu.be/Il1hdMKZ0QY
Caswell239 is offline   Reply With Quote
Old 07-20-2013, 07:04 PM   #2
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
My tensioner is no where near that close, may be your belt too long? Just a thought.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 07-20-2013, 07:11 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Hmm, it was the exact same as the whipple supplied belt. Ours do look so different
Old 07-20-2013, 08:12 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Under load at hi rpm, the tensioner will move towards the drivers side,in your case,it will touch the other idler/belt.
Use a shorter belt,use the pic the Kiwi posted as an example.
Motion427 is offline   Reply With Quote
Old 07-20-2013, 08:49 PM   #5
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Sir - I believe your alignment is off.....way ooooo0000ffffffffff.
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 07-20-2013, 08:50 PM   #6
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Where do you adjust front to back? Maybe space out the pulley bracket 1/8 or so
And correct me if I'm wrong the tensioner goes to the passenger side or downwards under load
Old 07-20-2013, 08:54 PM   #7
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
You have two idler pulleys to adjust. You probably forgot to adjust the bottom one. Just tighten it up and you should be good to go
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 07-20-2013, 09:29 PM   #8
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
That will adjust left to right, but it looks almost like I'm out front to back
Old 07-20-2013, 11:40 PM   #9
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Duplicate
Old 07-21-2013, 12:10 AM   #10
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
My belt rides close to the backside of my tensioner pulley as well, however my setup mirrors the pic posted by Kiwi_Camaro_2010. I'd have to agree that possibly the two idler pulleys are not adjusted correctly. Hope you get it worked out!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-21-2013, 07:54 AM   #11
BigMatt
BigMatt's Avatar
So does mine. These use the ten rib tensioner that's why it looks like it's riding toward the back. It's normal.
Old 07-21-2013, 01:19 PM   #12
MA2010SS
Why is there a 10 rib tensioner on a 6 rib system is my first question?
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 07-21-2013, 03:51 PM   #13
429
Drives: 2010 camaro ss
Your belt is routed wrong or adjusted incorrectly.
429 is offline   Reply With Quote
Old 07-21-2013, 05:40 PM   #14
BigMatt
BigMatt's Avatar
They started doing this a few years ago due to belt slip with their 6 rib tensioner. It's a much beefier tensioner
