03-12-2012, 01:13 PM | #1 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Brake fluid needed for full flush/refill
Anyone know how much brake fluid it would take to refill the system if I swap the Brembo calipers and switch to braided lines? I bought 3 pint bottles of Motul. But after splitting my clutch/brake reservoirs this weekend, it took nearly a pint just to refill the brake reservoir with DOT3 and I started thinking it may be tight with only 3.
03-12-2012, 07:52 PM | #2 |
I reinstalled all 4 calipers since I had them sent out to get powder coated. I went around the car twice to bleed each caliper and I used one full 16 oz bottle.
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
03-12-2012, 09:20 PM | #3 | |
Drives: 2020 ZL1 Join Date: May 2010
You'll need about a pint.
Take care not to run the master cylinder and the ABS module dry when you do the work - you need the dealer level scan tool to bleed the abs module if you get air in it. Quote:
2020 ZL1
03-13-2012, 08:00 AM | #4 | |
Drives: '69 SS Convertible Join Date: May 2009
I think I went around the car 3 or 4 times but the last time was just for good measure because I was surprised at how little it took. Now, if you're switching out fluid over to DOT4 it might take more till you see it in the caliper but still I would think 3 bottles would be plenty.
Build Journal |
03-13-2012, 11:18 AM | #5 |
Thanks for the replies. Yes I'm flushing it and putting dot4 in. I just bought a Motive Power Bleeder and going to give it a shot and see.
03-15-2012, 04:41 AM | #6 |
Drives: Silver 2012 1SS Join Date: Mar 2012
My car has DOT 3 fluid? I probably boiled the fluid already then. Wish I would have known that earlier. I have about 6 bottles of RBF600 in my garage. I could have swapped out the fluid before I decided to do any hard braking.
03-17-2012, 08:57 AM | #7 | |
Sent from my DROID RAZR using Tapatalk
06-26-2013, 11:50 AM | #8 |
Drives: 2010 camaro ss 6spdmanual Join Date: Nov 2012
You would know if your fluid boiled. The pedal will go straight to the floor as if you had no fluid. It pumps up within few pumps.
Similar Threads | ||||
Torque Converters | CamaroSpike23 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 48 | 08-16-2014 02:07 AM |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
Unbeatable Prices on BC / Eibach / Hawk / Hotchkis / MTI / Racing Brake / SLP / More | maperformance | Suspension / Chassis / Brakes | 10 | 10-04-2010 02:36 PM |
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL | ADKINS PERFORMANCE | Suspension / Chassis / Brakes | 0 | 08-03-2010 12:08 PM |
