Frankenstein Engine Dynamics
Old 10-09-2016, 12:18 PM   #1
ChasperL99
ChasperL99's Avatar
Drives: SW 2010 2SS RS
OEM pad replacement
Want to replace front pads this week, with same one with the roller skates. I have the new pads 22907156, 140.00. My question is, will the retainer come off, once I remove pins as easy as in the videos, I watched, or is their something I should be aware of or do. All the videos and DIY were without the skates. Thanks, for any advice or help.
ChasperL99 is offline   Reply With Quote
Old 10-09-2016, 12:22 PM   #2
failshift
Banned
Just as easy as the video. 10min job. I couldn't believe it either. I'm use to fanangling with c-clamps to compress the Pistons. Ect ect. Changing brembos is cake
failshift is offline   Reply With Quote
Old 10-09-2016, 03:58 PM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
you probably will need to tap the roller skates to get the pads out. But as failshift said, 10min job..... Changing brembos is cake.
Old 10-09-2016, 04:33 PM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
It sure wouldn't hurt to crack the bleeders and top off the fluid.
CamaroFred is offline   Reply With Quote
Old 10-09-2016, 05:07 PM   #5
ChasperL99
ChasperL99's Avatar
Thank you all for your help
Old 10-09-2016, 05:24 PM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS 6M
How many miles? Is the rotor smooth, have any hot spots etc? I personally either have the rotors turned or replaced...that way new pads bed in properly, last longer work better and save you $$$$....
read up on proper bed in
+1 on caliper bleed w/ fresh fluid
brakes are yer life...don't skimp...peace out
2010 SS 2SS M6-Spectre CAI-JET TBS-JBA Shorty Headers-ARH H/F Catted Mids-Doug Thorley axle back-MSD 12v coil harness mod-PAC 1218's-BTR 3/8 7.4 push-rods-Powell Machine bronze rocker bushings-Prothane motor mounts-Prothane rear sub-frame inserts-BMR Trailing Arms & bushings-1LE 3.91's-1LE axles-Ford S-spring posi-mod-Tune by RDP dynoSteve!(Woot)-LS9 block-Daily Driver-115K!-12.7 at 112-1.9 60'(3.45's)-BFG Comp-2 Street Tire-stock size on ZL1 reps(20x8.5)(20x9.5)-DR's Nitto NT05R(305/45) on Motegi MT120 18x9.5-12.6 at 108 - 1.7 60'(3.91's) All work by me...
Old 10-10-2016, 12:44 PM   #7
myold88
myold88's Avatar
My mechanic says to replace the rotors when doing the pads. It's not
like the old days as there's not to much meat on them to start with.
I've got 45,000 on my factory brakes so I'm due for new fronts soon.
Old 10-10-2016, 01:30 PM   #8
failshift
Banned
Not needed. unless you notice hot spots. Or warping (wheel shakes on braking, fronts are warped. Car shakes/bumps when braking, rears are warped)
Old 10-10-2016, 04:32 PM   #9
CamaroDreams76
I replaced the rotors when I did my pads. I measured the rotor and they were almost at the manufacturer throw away thickness.
Old 10-16-2016, 09:28 AM   #10
blackswan
blackswan's Avatar
Drives: Yes
Yes, I'd definitely replace rotors if they are original with that much mileage. Just not worth it not to given cost is so low for them. However, this will introduce greater cost above the cost of rotors, those caliper bracket bolts should be replaced. Sure some people don't, but it's not a best practice not to. Just did brakes on my 2LT and replaced rotors, not such a bad job overall. BTW, worth noting that I have 70k on original everything and pads looked good on outside. HOWEVER, the inside pads on front were horrible. Much more worn (presumably due to lack of caliper sliding) but also the metal shim totally disintegrated and the shim was a disaster - bloated rusting hulk and took up much pedal travel to compress each time I'm sure. Will post a pic if I didn't toss it, can't remember right now... So, lesson learned, 5 years on brakes in New England - don't guy by looks alone (on outside at least).
blackswan is offline   Reply With Quote
