Old 10-18-2016, 03:04 PM   #1
Adam63impala
Adam63impala's Avatar
Drives: 63' chevy impalaSS , 12'Cam89'Cam
Power steering fluid ? Can't find the correct fluid.
Having trouble locating the correct GM power steering fluid. Doing my 100k mile maintenance. It calls for
gm power steering fluid 89020661
Maybe the part number has changed ? Thanks !
Adam63impala is offline   Reply With Quote
Old 10-18-2016, 03:12 PM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2000 MCSS, 2013 1LS & 68 Camaro SS
Send a message via AIM to ChibiBlackSheep
Looks like the new part number is: 89021182
Here's a thread from BobIsTheOilGuy: https://www.bobistheoilguy.com/forum...Number=2531248
Or a link to buy: https://www.amazon.com/Genuine-Fluid.../dp/B00BK7MHOE
2013 Camaro 1LS - Daily Driver
1968 Camaro SS - Show Car
2000 Monte Carlo SS - Paxton Novi Supercharged Project
2008 Impala LT - Because we need at least ONE family car
ChibiBlackSheep is offline   Reply With Quote
Old 10-18-2016, 03:16 PM   #3
Adam63impala
Awesome thank you man.
Old 10-18-2016, 03:25 PM   #4
ChibiBlackSheep
No problem!
Old 10-18-2016, 09:25 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
Why not use a synthetic from RP or other top tier oil maker.
Orange Krush II
1LE Front with DSE Links and Rear Sway Bars, Splitter, 3.91 Gears with 1LE Axles, 14/15 Heat extractor in a 13 1LE hood, 1LE shocks and struts,1LE Suede Flat bottom Steering wheel restitched in orange, Factory Hurst short throw shifter with the Pegasus rear poly shifter mount, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, Skip Shift eliminator, 1LE diffuser with dual mode mufflers, Z/28 headers and Cats, 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers and CTS-V Rotors, PAFDT Solid Cradle bushing, Z/28 Toe Rods and UCA Bushings.
