Old 05-17-2017, 05:11 PM   #1
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
Talking Unknown interior squeak coming from boot area
Unless the road is super even, I'm hearing a squeak coming from the console. I tried holding down any grey plastic I can but the only thing that appears to suppress it is holding the automatic shifter boot.
Anyone else experience weird interior squeaks on the console and possibly know the solution?
TastyBake is offline   Reply With Quote
Old 08-18-2017, 10:33 PM   #2
PatrickS
PatrickS's Avatar
Drives: 2011 2LT RS
This is an older post, though I have the same squeaky issue! Haven't found what is making the sound
PatrickS is offline   Reply With Quote
Old 08-21-2017, 09:48 AM   #3
mbesman
Drives: Camaro SS
I had a squeaking sound too. The culprit was the driver center air vent. The little center part rattled because it was not flush. Had just enough of a gap to rattle. I pulled the dash and than the vent out and placed a little fuzzy sticky in between the center strip. The kind you use under lamps and stuff. Now I have no rattle. Drove me up the wall. Easy fix. about 5 cents.
2015 2SS
mbesman is offline   Reply With Quote
Old 08-21-2017, 01:19 PM   #4
PatrickS
PatrickS's Avatar
Drives: 2011 2LT RS
Thanks! That sounds very possible to what mine is then! Now that I think of it, it seems to have started not long after air conditioning season started. I'll check it out!
Old 08-22-2017, 02:01 PM   #5
jethrobandit
Drives: 2013 Black 2SS
I have a massive one that drives me nuts. I have held down every part I can touch, tried to crawl up under the steering wheel, taken it to the dealership, and looked at everything from the hood hinges to things attached to the firewall. And nothing. I've posted about it on here before and haven't gotten any responses.
Mine seems to originate from around or to the left of the steering column. But, passengers hear it in different areas too. Someday I'm going to rip out the dash...
jethrobandit is offline   Reply With Quote
Old 08-29-2017, 03:04 PM   #6
jethrobandit
I fixed my squeak finally...
Installed a cam and long tubes and now I don't hear a damn thing other than sweet engine noise...
Old 08-29-2017, 03:54 PM   #7
gen5dewy
gen5dewy's Avatar
Drives: 2015 Black 2SS/RS
sounds like the perfect fix to me
2015 2SS RS Roto-Fab Intake Borla Atak Cat back
Drive fast on empty roads with nothing in mind except falling in love and not getting arrested
https://www.instagram.com/gen5dewy/
gen5dewy is offline   Reply With Quote
Old 09-25-2017, 06:18 PM   #8
camarodragonL99
Drives: 1967 Camaro, 2010 Camaro
I know the sound. I have a 2010 automatic. Mine comes from the shift slider. The black plastic part that traverses with the shiftier. Its like plastic on plastic crackling. If i hold down the plastic right under the shift rod it goes away. I was thinking some lube may help it but in order to access I may have to remove the console. I don't know how hard that would be.
ya it drive me nuts. All the little lines in the road. You hear them all.
camarodragonL99 is offline   Reply With Quote
Old 09-25-2017, 07:32 PM   #9
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
My crap noise:sun glasses moving in the door, and tons of stuff in the console and where ever rattle is usually them. But hey its not very noticeable.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
