Old 09-05-2014, 09:54 AM   #1
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
Anyone use these headers ??
Anyone use these ? says they are a direct bolt up to the stock exhaust. Is it worth the hp gain as compared to Long Tubes ?? More importantly, do these prevent throwing any codes ???
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 09-05-2014, 10:06 AM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
You won't gain much bolting them up to the stock cats, that's where a good bit of the power from longtubes is gained.
I would say you might get 10 hp from just bolting those onto the stock cats.
If you want to stay un-tuned you might be able to get away with the short tubes along with some stock replacement high flow cats, you may not get a CEL then and wouldn't need a tune. If you can do that you'll gain much more power than just swapping the manifolds for shorties.
Basically, not worth the money you spend for the HP gain unless you pair them with cats, or you just want the sound.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 09-05-2014, 10:06 AM   #3
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Yep work great...look even better...the jba spark plugs wires in red really add a nice touch.
rontammy0 is offline   Reply With Quote
Old 09-05-2014, 10:08 AM   #4
rontammy0
Here is how they look on the car
Old 09-05-2014, 10:12 AM   #5
rontammy0
I have these bolted up to solo hi flow cats...no tune with these is needed ...emissions legal as well. You will see better gains with the hi flow cats .....together they make good power with great sound.
Old 09-05-2014, 10:24 AM   #6
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
We have bolted these up and tested them. You will see about 10 HP with the Factory Cats. You can also get these in 3 different finishes. Stainless PT#1812S, Silver Ceramic Coated PT#1812SJS, and Ceramic Coated Titanium #1812SJT. These will also work with the Turbonectics Single Turbo Kit. Another good thing about these Shorty Headers is that they are CARB legal.
Sales@Phastek is offline   Reply With Quote
Old 09-05-2014, 06:01 PM   #7
MightymouseSS
Drives: 2011 LS3
I used to have that exact set on my car into oem cats. Its help a lil bit but not much. Id say if your gonna put some hf cats you'll see better results. But if you run the numbers after these shorties and hf cats you might as well go with LTs in the first place.
Stainless Works Headers
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Tuned by Southwest Speed
MightymouseSS is offline   Reply With Quote
Old 09-06-2014, 12:27 PM   #8
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Unless you live somewhere with restrictions against long tubes or are extra concerned about warranty issues, you should go long tube. A tune is highly recommended with long tubes, not so much with short. The performance you get from long tubes are not only superior as is, but will assist future performance mods in reaching their full potential.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 09-06-2014, 03:17 PM   #9
mikeyg36
Drives: 2015 Z/28 #533
It's a waste compared to long tubes.
mikeyg36 is offline   Reply With Quote
Old 09-06-2014, 10:37 PM   #10
Smkn600CTD
Smkn600CTD's Avatar
Drives: 2013 Camaro SS and 2014 SS Sedan
Unless you in live California where they are the only LEGAL option. Long tubes don't fly here!
2016 Lexus GS-F
2014 SS Sedan #2577/3537
2013 Camaro 2SS/RS.
2013 Camro ZL1 Vert
2009 Dodge Daytona Charger #332/400
Smkn600CTD is offline   Reply With Quote
Old 09-06-2014, 11:01 PM   #11
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I have never used those headers......I have had BBK's shorties, and I would say just spend your money on toilet paper, you'll be a lot more satisfied when its all said and done.
I gained 7WHP with my shorties and no CEL
If you are trying to compare them to LT's...its no comparison, the difference is like night and day....IMO
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-06-2014, 11:02 PM   #12
YAKACHE
Drives: 2011 Camaro 2SS RS
Shorties are just to compliment the engine bay. What gives you more power is swapping those four heavy cats for high flow cats. Jba or solo mid pipes is what you need. And if you still want shorty headers then it'll be up to your taste in color coatings. Good luck.
YAKACHE is offline   Reply With Quote
Old 09-06-2014, 11:56 PM   #13
rontammy0
Hmmm 10 hp..without cats..i wonder what they would pull with the solos..op these headers work well when hooked up to hiflows..i cant give you a number...seems nobody can for some reason, You would be happy with them. Its all up to you.
Old 09-07-2014, 06:05 PM   #14
jag107
jag107's Avatar
Drives: 2010 2SS/RS IOM M6
I put in those JBA shorties with the JBA hi flow cats and got a code about 500 miles later. If you don't mind the light, you'll love the sound and extra power. I didn't dyno and I did the swap all at once so I don't really know what the shorties did, I'd assume the hi flow cats did the most power wise but anyway if you're gonna do the shorties do the cats at the same time, it'll be worth it.
Placed order: 02.25.2010
Took delivery: 04.06.2010
Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links
jag107 is offline   Reply With Quote
