10-26-2014, 10:38 PM | #1 |
I can't tell if I have an exhaust leak after headers????
You know what sucks about living in a small town? You have no other cars to compare to...I just recently installed TSP 2" headers and I'm trying to see if I have an exhaust leak. When I'm riding along, mostly next to walls or other cars, I hear a light ticking. When I get out of the gas and coast in neutral it goes away. Is this "ticking" normal? It's very light and you can't really hear it at all with the windows up. If it's normal I'm cool with it, if not I need to fix it. It doesn't get any louder with acceleration and it doesn't have the "psst psst" noise its just ticking. Actually the roar from the exhaust and engine together cancel it out once you pass, say, 2,800 rpm. Any help is appreciated.
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
10-26-2014, 10:55 PM | #2 |
145lb Powerlifter
Drives: 2013 Camaro 2SS RS LS3 Join Date: Jan 2014
All headers "tick." Cast iron exhaust manifolds are thick and fabulous at suppressing engine noise and exhaust pulsations. When you switch to a comparatively thin header, ESPECIALLY STAINLESS STEEL headers because they're quite thin, you start hearing all kinds of new ticks you couldn't hear before.
In this case, ticking is a poor judge of whether or not you have an exhaust leak. Instead, check for soot. If you have an exhaust leak, after a few weeks you'll start seeing black carbon deposits around seals and gaskets. If you see black rings or streaks, you have a leak. If after a few weeks the connection points are spotless, you're tight as a drum.
10-26-2014, 11:08 PM | #3 | |
10-27-2014, 08:27 AM | #4 |
Drives: '13 Dusk Edition 2SS/RS M6 Join Date: Nov 2012
Mine have always ticked...especially next to barriers that reflect sound like you describe.
Ive heard it in every car with headers
10-27-2014, 09:00 AM | #5 | |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
10-27-2014, 09:17 AM | #6 |
Please excuse the newbie...I modded diesels in my passed life haha
10-27-2014, 02:51 PM | #7 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
I agree with the guys above, my car is noisier after headers, just like described.
If you have an exhaust leak up at the heads it would get louder and faster under load/increased rpm. It's usually quite noticeable as well, without something for the noise to reflect off of.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
10-27-2014, 03:40 PM | #8 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
That's someone relieving to know. I also have 2" TSP headers and I swear I have a leak someone. No soot or anything of the sort but, I also hear ticking. On previous cars, I heard nothing of the sort so, I just assumed that I had a leak. I'd still keep an eye out if I were you, just in case.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
10-27-2014, 04:07 PM | #9 | |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
10-27-2014, 04:13 PM | #10 | |
10-27-2014, 04:40 PM | #11 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
I checked a few months ago and had several soot marks on both sides of the motor where the LTH's were connected. The person that installed them used the stock gaskets instead of the silicon that Stainless Works recommends..
Another fellow Camaro owner checked his (same LTH's, same installer) and did not have any signs of leaking.. Just FWI to any SW LTH owners... |
10-29-2014, 07:05 PM | #12 | |
10-29-2014, 08:10 PM | #13 |
Too much is never enough!
I remember about a month after I bought my car, I noticed the ticking. I was so pissed, thought I had a bad lifter.
From what I have read here on C5 the ticking is normal for our cars to tick. After I installed my LT's and deleted my cats I hardly notice it anymore. People say that the LT's will make the ticking worse, yet for me I think it helped it. As stated previously in this thread. You will want to recheck the torque on all your nuts and bolts. They will loosen up after some miles on the car.
10-30-2014, 07:17 AM | #14 | |
145lb Powerlifter
I would recommend you retighten the bolts where the headers meet the gaskets/heads on your motor. They tend to back out slightly from the initial vibrations of the motor. After you retorque them after a week or so of driving they should stay put. Your best chance of leaks are at the collectors underneath the car where the headers meet the cats and the cats meet your crossover pipe. Check your band clamps for soot, or whatever method you used. I'm assuming you didn't weld your collectors.
