Old 11-09-2014, 09:44 AM   #1
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
got down in the 11's
ran 11.36 friday night for just n/a built camaro. but my rear end blew out after launch it ran but the posi is trash now so no telling if it could have went faster
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 11-09-2014, 10:05 AM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Damn that sucks about the rearend, how is it that your killing them?
62nalide is offline   Reply With Quote
Old 11-09-2014, 10:06 AM   #3
smokum
smokum's Avatar
Drives: 2010 2ssrs
Time for a diff upgrade! Maybe a gear change to get the max out of your setup.
smokum is offline   Reply With Quote
Old 11-09-2014, 10:07 AM   #4
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
Nice run, do you mind if I ask what you are running for your rear suspension setup? I'm have similar HP and similar trap speeds, I just can't seem to get that launch down to break into the 11's. Of course our DA is a little different, but if I can drop that 60' time I should be in the 11's
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 11-09-2014, 11:58 AM   #5
sasquash1984
502 RWHP N/A
Drives: The yeti
my suspension is bmr trailing arms, bushings on rear diff and upper control carbon fiber bushings, i just upgraded from 3:45 to 3:91 in august. first time i broke the spider gears from posi locking on one side while doing burouts 2 yrs ago. the car drives but when turning the inner rear wheels lock
Old 11-09-2014, 01:25 PM   #6
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
It's getting better. I barely saw you there the line was so long.
Camarojt is offline   Reply With Quote
Old 11-09-2014, 01:34 PM   #7
white ZL1
Drives: none
Mikes a racin m'fer! Shits gonna break.
Definitely would have been faster too.
white ZL1 is offline   Reply With Quote
Old 11-09-2014, 02:59 PM   #8
sasquash1984
502 RWHP N/A
Drives: The yeti
I believe im over 630 passes in 3 yrs
Old 11-09-2014, 04:07 PM   #9
white ZL1
Drives: none
That's awesome!!!
Old 11-09-2014, 09:48 PM   #10
Camarojt
Camarojt's Avatar
You got your timeslip?
Old 11-10-2014, 01:50 PM   #11
sasquash1984
502 RWHP N/A
Drives: The yeti
I posted in the fast list
Old 11-10-2014, 05:06 PM   #12
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Working on down!!! Nice Job!
Rhino79 is offline   Reply With Quote
Old 11-10-2014, 07:24 PM   #13
white ZL1
Drives: none
Hey Mike....
Can you post a pic of your fastest 1/8 mile slip next to the slip from friday night?
Old 11-10-2014, 10:21 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
630 passes dang!
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
