01-27-2015, 01:11 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2015
JBA catless midpipe install!
I'm looking for a shop to install my midpipes, im located in Santa Clarita but will travel to the valley if needed.
Any help would be great. |
01-27-2015, 05:20 PM | #2 |
SoCal HT5 COTW 4/21/13
Drives: 2011 SS/RS Blown & Cammed LS3 Join Date: Sep 2011
Do them yourself its not very hard. Or if you want to make the drive down here I will help you put them in
01-27-2015, 06:29 PM | #3 |
Drives: 2010 2SS/RS IOM M6 Join Date: Sep 2007
Just make sure you snug them up real good so you don't get exhaust leaks, and be ready for codes. They really do give a nice boost!
Placed order: 02.25.2010
Took delivery: 04.06.2010 Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links |
01-29-2015, 02:48 PM | #4 |
IG @arod221_L5P
Drives: 2024 GMC 2500HD AT4 Join Date: Aug 2012
grant never seems to think any part install is difficult.....i've yet to see him work on anything by himself though lmao!!!!
My Build Threads
2013 AGM 2SS/RS ***SOLD*** http://www.camaro5.com/forums/showthread.php?t=374535 2017 NGM ZL1 ***SOLD*** https://www.camaro6.com/forums/showthread.php?t=548637 ***SEARCHING FOR*** 19-24 RBM ZL1 M6 W/ VISIBLE CARBON HOOD |
05-13-2015, 06:14 PM | #5 |
Drives: 2017 RED HOT SS Join Date: Feb 2013
I tired getting my Midpipes swapped out here in So Cal,but none of the muffler shops here would do it cause i am taking the cats off !!
And i rather not attempt it myself ,i might not have the right tools to get the O2 sensors off ! With my luck , i will probably get a stubborn O2 sensor .LOL. The search continues !! |
05-13-2015, 06:49 PM | #6 |
Rogers exhaust, they did mine. There in Fontana.
05-13-2015, 09:26 PM | #7 |
Drives: 2010 Camaro SS Join Date: Mar 2015
Just get a couple of jack stands and a creeper. If you have a crescent wrench, you should be able to get the o2 sensors out. If they are stubborn, just hit them with some pb blaster and let them soak for a few minutes. Mine were stubborn and I ended up just getting a good angle and hitting/kicking the wrench down. Also, it helps out a lot to take the bracket off that is about a foot or so aft of where the pipes bolt up to the catback. That way you can move the catback around to fit up to the off road pipes. But if you do that, just make sure not to let the catback hang, as it will stretch the exhaust hangers. All in all, even at a beginner level, just doing those mid pipes should only take you 30 minutes to an hour. I dove into my long tubes install, and that was a bit more daunting. Best of luck. =D
05-15-2015, 05:49 PM | #8 |
Thanks guys for all the info.
Really appreciate it ! |
05-15-2015, 05:55 PM | #9 |
Tried calling Roger exhaust shop in Fontana.
But the same answer , it's illegal and they wouldn't. Do it .ugh! |
05-15-2015, 06:05 PM | #10 |
Just go there they did mine.
05-15-2015, 06:17 PM | #11 |
Drives: 2015 Camaro SS 1LE Join Date: Dec 2014
05-15-2015, 06:55 PM | #12 |
I just didn't want to drive 45 minutes to tell me they can't do it .
But I guess your right , that what they have been instructed to say over the phone .lol |
05-22-2015, 08:59 PM | #13 |
A basic socket set and a crescent wrench will get it done, man. Just sayin...
