Old 08-29-2015, 02:43 PM   #1
Blk Betty
Drives: 2011 ss
Camaros first trip down track on chase for 11s
Not new to the track but new to the camaro scene
Cars mods are
Custom cam
Kooks 1 7/8
Borla atak
Vmax tb
K&n intake
Ud pullies
Made 470rwhp
Last night in 1000ft da she went 12.95@115.44 with a 2.3 60ft
I kno the 60ft sucks but tires are bald bald
Need advice I need that 11.99 on street legal radials
Need advice from the camaro gurus on here
Blk Betty is offline   Reply With Quote
Old 08-29-2015, 04:00 PM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I would change ring and pinion and get a set of drag radials.
MODS:
Old 08-29-2015, 05:36 PM   #3
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Go all out 15" rim conversion. Wish i had of done it in the 1st place.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 08-29-2015, 05:52 PM   #4
Blk Betty
Drives: 2011 ss
I honestly can't swing the cash for all out 15 conversion I'm looking at the c6 rims with some mt et streets on them a new clutch 4:11 gears and trailing arms. Dropping front sway bar along with a little weight
Old 08-30-2015, 04:38 PM   #5
Blk Betty
Drives: 2011 ss
Any other words of advice or parts that will help
Old 08-31-2015, 10:03 AM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Drag radials + some rear suspension parts. The latter are needed to minimize wheelhop.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-31-2015, 12:00 PM   #7
2010SSRSM6
2010SSRSM6's Avatar
Suspension and seat time.
I think my best before the blower was 12.10 on street tires (stock p-zeros) with 460rwhp.
Old 08-31-2015, 12:46 PM   #8
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Its going to take seat time man. Im still chasing 11s on my setup. My problem is getting off the line clean. Im running 20" 555Rs and my best 60' to date is 2.0. Ive seen them do 1.8s so I told myself Im not buying anything for the car until I do 1.8 60ft and 12.3 in the 1/4. (Current best is 12.76) I live in AZ and our track is known to be a slow track. The only thing I may cheat on and buy is a clutch. Its been getting stuck to the floor when I try to leave harder. I separated the reservoirs and havent been back to the track to see if it fixed the issue. Too damn hot. Lol!
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 08-31-2015, 02:08 PM   #9
62nalide
62nalide's Avatar
Drives: 2013 SS
That should be a low low 11sec setup with the right traction support
62nalide is offline   Reply With Quote
Old 08-31-2015, 03:17 PM   #10
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Auto or stick if auto need stall 3600 or higher with supporting rear suspension and drag tires
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 08-31-2015, 05:07 PM   #11
Blk Betty
Drives: 2011 ss
Ok so I just got a pair of 18 corvette rims with mt et street 305/45/18s
And BMR trailing arms and outter bushing
Aswell as going to drop front sway bar. Any other recommendations
And it's a manual car
Old 09-01-2015, 12:01 AM   #12
sasquash1984
502 RWHP N/A
Drives: The yeti
Axles
Old 09-04-2015, 10:14 AM   #13
2010SSRSM6
2010SSRSM6's Avatar
Depending on your budget, Eaton Trutrac, 3.91's and axles.
Old 09-04-2015, 11:34 AM   #14
bct10985
Drag spec rear alignment
