08-05-2011, 09:52 AM | #1 |
Drives: 2010 Camaro 2SS Join Date: May 2011
New to Camaros need some suspension advice.
Let me first start by saying I am new to camaros but not cars in general. I have always owned cobras and wanted something different this time an am loving the camaro so far.
Last week I bought an awesome Cammed and Whippled camaro from the for sale board here from a great member. Along with the car he included alot of suspension componets he had not installed yet. So my question is from the parts list below what should I install and what if anything do I still need. It is a few different brands should I try and stick with the same brand on everything or try and sell some and purchase others. Also any advice for any possible issues or problems with any of these parts. Do I need camber bolts when lower? You get my point. Thanks in advance for the advice! Pedders: 428020/27a Sway bar 220032 front springs 1" drop 220033 rear springs 1.5" drop EP6577 radius rod bushings EP1167HD Differntal bushings EP1201HD subframe bushings BMR: TR003H toe rods PFADT: 1410118 trailing arms What if anything should I do at same time or change about this list. Car has 626 rwhp and will be mainly a weekend street car with some trips to the 1/4 drag strip. |
08-05-2011, 11:24 AM | #2 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Looks like a pretty solid setup since you did inherit it from the previous owner. All those parts will play well with each other, although every company has different ideas as far as what will work the best for each particular product. I'm not sure it's how any of the Vendors would have put a kit together, and while it may not be optimal from that perspective it should be pretty functional when it comes together.
For best drag strip performance you actually don't want too much negative camber, so the stock adjustment bolts should be good for your setup. Go have fun with the new car! Looks like a blast. |
08-05-2011, 11:31 AM | #3 |
knows 2 facts about ducks
This is a very good read --> Suspension-The Book
08-05-2011, 12:52 PM | #4 |
Drives: Camaro Justice Join Date: Jun 2007
Your car with the parts you have listed should be awessome. The key to making it all work is a good alignment. Is there any chance the previous owner provided an aligment ssheet?
08-05-2011, 01:09 PM | #5 |
Thanks for the feedback so far. No alignment sheet given. Car only has 5k on it so it may still be factory alignment. Been trying to do some research on all of these parts. Since I seem to have the HD bushings will I have a large increase in road noise. I guess it cant be any worse than the horrible drone from the exhaust at 70
08-05-2011, 01:16 PM | #6 | |
Please make sure you get a before and after printout and follow up with you driving impressions. |
08-05-2011, 02:09 PM | #7 |
I am assuming you are talking about getting the alignment once I get all of this installed right? Would not like to pay for two alignments. Any comments about the EP1201HD as far as being mainly a street car? Or should I look at exchanging these for the EP1201. I just don't want to regret installing of this when I am done. Also the same with the springs is the 1.5" drop in the year to much for a mainly street driven car? thanks again for all of the help just want to get it all right the first time. I assume this won't be a lot of fun laying on my back in the garage.
08-05-2011, 02:11 PM | #8 | |
Dances With Mustangs
My project thread might have some useful info for you: http://www.camaro5.com/forums/showthread.php?t=45165 The Pedders bushings make a huge difference in the way the car rides, handles and performs. Well worth it.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
08-05-2011, 02:16 PM | #9 | |
If you're sticking with the factory 20" wheel size then a 1.5" drop is fine. If you go down in wheel size it will still work but you have to watch clearance on steep driveways and some speed bumps in parking lots.
08-05-2011, 02:29 PM | #10 | |
08-05-2011, 02:40 PM | #11 | ||
Drives: 10 1LT SIM; 91 B4C sleeper Z Join Date: Aug 2009
08-05-2011, 02:43 PM | #12 |
08-05-2011, 03:01 PM | #13 | |
Wow! He hooked you up! Why did he sell? |
08-05-2011, 03:15 PM | #14 |
Needed to get rid of the car and everything came with it.
Similar Threads | ||||
GM builds race-ready SSX Camaro and chooses Pfadt Race Engineering suspension | PfadtRacing | Suspension / Brakes / Chassis | 55 | 07-14-2011 04:20 PM |
Suspension Planning, need advice please | bigsquirrel | Suspension / Brakes / Chassis | 27 | 12-02-2010 09:34 PM |
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 80 | 11-17-2010 02:28 PM |
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! | Circuit Motorsports | Suspension / Chassis / Brakes | 99 | 05-24-2010 04:21 PM |
Certification Camaros for Track II & eXtreme Xa Needed | Info@PeddersUSA.com | USA - Northwest / Pacific Northwest | 4 | 04-30-2010 06:05 PM |
