04-09-2014, 05:16 PM | #1 |
Drives: 2013 Camaro 2SS L99 A6 Join Date: Oct 2013
L99 to LS3 conversion?
is it worth it? or should i go with a custom cam from rhino? what do both options usually run (just parts, install i can imagine how much it would be). what HP/TQ gains are normally expected from either option. thanks.
2013 2SS A6- Vette Doctor tuned-375whp 392wtq
cold air inductions intake stainless power 1 7/8" headers stainless works HF cats stainless works 3" retro chambered exhaust full de-badge of entire car |
04-09-2014, 05:44 PM | #2 |
Drives: 2013 SS Join Date: May 2013
If you want a big boy VVT cam you need a good 3600 converter. Ls3 conversion kits are a waste of money theres tons of guys converting back to VVT
04-09-2014, 05:57 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
There are at least 8 threads on cams on the first two pages. No one knows what YOU want. We can just tell you what others are getting. Either way you go, if you go with a decent sized cam, you'll need a 3200+ converter.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
04-09-2014, 06:05 PM | #4 |
Good point
04-09-2014, 06:14 PM | #5 |
502 RWHP N/A
I have had the ls3 conversion for 2 years but now I'm wanting to go faster without putting $7-$10k into boost applications so going to a big vvt cam
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
04-10-2014, 05:03 PM | #6 |
can someone give me rhinos user name so i can discuss what i should go with from him? ive decided if im going to cam it im going to do a VVT cam and i need to know my options and prices..
04-10-2014, 05:05 PM | #7 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
I love my 500 RWHP LS3 conversion. Pat G. spec cam. Not a waste of money at all.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
04-10-2014, 05:57 PM | #8 |
Drives: 2010 Camaro Auto Join Date: Mar 2010
What do you consider a decent sized cam?
Just livin' life |
04-10-2014, 06:07 PM | #9 |
502 RWHP N/A
04-10-2014, 07:34 PM | #10 | |
Love how you can make over 500RWHP with the stock untouched heads keeping the VVT
04-13-2014, 12:02 AM | #11 |
RSCHRIS
I would love to have this conversion done to my L99 but i just also want to get rid of AFM and keep vvt. then figureing a new head and cam would be nice.
