12-20-2016, 07:07 PM | #1 |
Drives: 2015 camaro 1le Join Date: May 2016
305 or 315?
Can anyone tell me if this is a 305/35 or 315/35 ?
They are gforce Thx |
12-20-2016, 08:53 PM | #2 |
Too much is never enough!
Picture too blurry to zoom in on.
12-20-2016, 10:12 PM | #3 |
Fronts are 285/35 im going to guess 305 out back
12-20-2016, 10:45 PM | #4 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Looks like a 1LE. Stock tires are 285s all around, and that looks like a BFG Rival. The new Rival S isn't available in a 20" size, but the older ones were. I think it's a 285/35/20, same size as stock. Rivals run wide. I know a 305/35/20 would have filled an 11" wheel no problem.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
12-21-2016, 07:41 AM | #5 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
If it is a G-Force it is a 305, because they do not make a 315. Also looking at that picture and the way it is tucked in, I think that is a 285 on that rim........
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
12-21-2016, 09:37 AM | #6 |
Drives: 2015 1le 2ss/rs Join Date: Dec 2016
I think they are 305s, if they were 285s you would see where they kinda of stretched the tire to fit it.
12-21-2016, 10:14 AM | #7 | ||
Captain Gingerbeard
The 305 Rivals had a 12.5" section width on an 11" wheel.
