08-25-2012, 09:24 PM | #1 |
Drives: 2011 camaro 2ss/rs Join Date: Apr 2012
intake & throttle body
if i do the ls3 upgraded heads for the l99, and cam is it worth doing the intake and throttle body will they add that much bang for the buck . and can someone tell me what the hell a trunion on the heads is and does this need done
08-25-2012, 10:20 PM | #2 |
The intake and TB is the same from L99 to LS3.
08-25-2012, 10:24 PM | #3 |
Drives: his wife crazy buying mods Join Date: May 2012
Are you talking about porting the intake and throttle body?
As far as the trunion upgrade 6 say yes, and a half dozen say no. Kinda like the oil pump upgrade.
Gone But Not Forgotten
08-26-2012, 09:11 AM | #4 |
Drives: 2010 2SS/RS Camaro CGM Join Date: Aug 2011
I would recommend porting the stock LS3 Intake and Throttle Body over investing in a Fast102mm and Nick Williams 102mm throttle body...
the ported stock parts flow nicely... Katech dynoed a BER ported throttle body and LS3 intake against a Fast 102mm Intake and NW 102mm TB... the Fast/NW combo gained 8whp and 7 ft-lbs... the BER ported stock parts gained 7whp and 5 ft-lbs.... and that was on a heads/cam car... so while neither are big gainers, spending $1500 on a Intake and Throttle body is pretty pointless when the stock parts ported can give you similar gains for $500 in porting
2010 Camaro SS L99... has a few mods |
08-26-2012, 09:14 AM | #5 | |
Drives: Florida Speed & Power Join Date: Jan 2011
08-27-2012, 07:26 PM | #6 |
thanks everyone looks like porting the stock ones is the way i will go, save the money for other mod's
